what would you charge?
Discussion in 'Fox 5.0 Talk' started by rednotch88, Jan 24, 2009.
  1. rednotch88 Member
    Sep 7, 2008
    Message Count:
    153
    CHICAGO
    What would you charge someone to put a granatelli mass air conversion kit in?I got a job lined up but don't wana work for pennys.let me know
    Thanks.
  2. DeVus1 Founding Member
    Mar 30, 2002
    Message Count:
    419
    26
    P-Town, Va.
    A couple of screws and a little bit of wire running? Charge him a 12 pack and call it a day.
  3. DeVus1 Founding Member
    Mar 30, 2002
    Message Count:
    419
    26
    P-Town, Va.
    And if they really paid $945 for it, they should seriously get their money back.
  4. Cobra912 Active Member
    May 1, 2005
    Message Count:
    1,843
    38
    Wish I was anywhere but here
    it's not a very big job (I've done it) so not much
  5. rednotch88 Member
    Sep 7, 2008
    Message Count:
    153
    CHICAGO
    $100.00 ?this isn't a friend or anything.Doing it for work.Money is tough now mabey the ol 12 pack thing would work last
    Also he has no heat,tools,and im in good old Chicago so its not warm....also have to go to east side where its not fun to be.winter nor summer.
    Devus what are you talking about ......with 945.00?
    Now what would you charge to change full harness?
  6. Evilfox New Member
    Dec 3, 2008
    Message Count:
    48
    Elk Grove, Ca
  7. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,649
    9
    78
    Massachusetts
    Wow...that's a seriously overpriced kit
    I used this kit
    IST Products
    $40 for the harness, $75 for a computer and $35 for a stock MAF + intake tube setup off ebay. Worked like a charm. Took a few hours to wire. You do gotta tap into a few wires under the car so it's a little PITA getting there.
  8. rednotch88 Member
    Sep 7, 2008
    Message Count:
    153
    CHICAGO
    what about convert whole harness he got harness comp and mass meter.What would you charge for LABOR?for what I hear his brother told me he has money.hah dono why he said that guess he's trying to tell me to juice him for some $$
    mustang 5l5 the harness was bought for about 40.00 on ebay i was talking labor to install.
    Evil fox **** that 900+ kit hahah id scrounge thru the bone yard before telling anyone to lay that kinda money down.
    one more thing needed to know are there salt ad pepper shakers on the speed density im assuming so....?
    quick response please and thank you
  9. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,649
    9
    78
    Massachusetts
    More than likely the Ebay harness is the IST harness.
    It's fairly easy to install. However, if the car is not a cruise control car, you will need to buy a VSS sensor and add it. Make sure it's a CC car first.
    As for labor? $75?
  10. rednotch88 Member
    Sep 7, 2008
    Message Count:
    153
    CHICAGO
    75.00 for change of full harness?a factory mass harness?
    i never owned a speed density does it have salt and pepper shakers or does the motor harness have to change too?
    im not doing the little conversion kit im doing the full eec harness.
  11. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,649
    9
    78
    Massachusetts
    Full factory harness??
    What year is the car and what year is the harness from??
    Only a 1989 harness will work in an 86-88 Mustang
  12. rednotch88 Member
    Sep 7, 2008
    Message Count:
    153
    CHICAGO
    it is an 1989 harness and why will an 89 only work out of curiousity and future reference.anyway what you think for a conversion like this labor wise $150-175?$
  13. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,649
    9
    78
    Massachusetts
  14. rednotch88 Member
    Sep 7, 2008
    Message Count:
    153
    CHICAGO
    this is just the main harness off computer to the engine bay that link you sent me is taking about dash hook-ups being different i don't believe this harness goes under dash just into the engine bay from the ecu?correct...?does it plug under dash ?
  15. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,649
    9
    78
    Massachusetts
    The harness that connects to the computer goes out into the engine bay, but also has one plug that connects to the dash harness. Depending on the year, it may or may not interconnect.
    But since you have an '89 harness, you should be all set if you are putting it into an 87-88
    BTW, why did you say you were installing a granatelli mass air conversion kit when you have a factory '89 harness?
  16. rednotch88 Member
    Sep 7, 2008
    Message Count:
    153
    CHICAGO
    guy first told me he had that kit.then told me had harness.sorry for confusion.ima double check that its an 89 harness.thanks for the help man
  17. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,649
    9
    78
    Massachusetts
    Make sure it has cruise control. I think Mass Air cars need to have the VSS added on the speedo cable. Speed density cars without cruise were not equipped with this.
  18. rednotch88 Member
    Sep 7, 2008
    Message Count:
    153
    CHICAGO
    im doing the conversion on an 88 notch.I believe I have an 89 harness i must double check but if i do.now i must make sure it has CC?and if it don't?sorry im all over the place here runnin around back to computer..
  19. uedlose Founding Member
    Jan 25, 2001
    Message Count:
    638
    Charles Town WV.
    I just did this a few weeks ago. I did it the right way, just like ITS I ran the wires over to the speed sensor . I also solder everything and heat shrink it all I pulled the front seats out and the center console also to run everything did a nice neat job I charged $150 plus parts, mass air plug, wire shrink wrap,wire loom, wire and tape.
Share This Page
