What Year Intake/heads Off A Explorer Fit Mine '90 Notchback?
Paul Randle
87
orlando
I have got mixed thoughts on what year explorer heads and intake fit the 5.0 motor. I need a bolt on intake and heads. I was told that only the '96 bolts on then i was told that only '99 bolts on. Can anyone help me?
Both will bolt on directly.
The '96 and early-'97 intakes have the internal EGR provision like your stock manifold which is necessary if you want to remain smog compliant.
The mid-'97 and up intakes used an external EGR system and are therefore not cast to retrofit your current EGR hardware. As such, your EGR would not fuction.
Reactions: 1 user
Also, keep in mind you will have to drill and tap the #5 runner in the Explorer lower intake to retrofit your stock manifolds ACT sensor. Not a big job, but necessary if you want to instal the sensor in the factory location.
Reactions: 1 user
oh wow cool good thing to know lol. I have a stupid question for you, other then that the heads and the upper and lower intake can just be bolted right on right? will i need any additional parts?
