Whats better?
Discussion in 'Classic Talk' started by Cobain03, Oct 5, 2005.
  1. Cobain03 New Member
    Aug 27, 2003
    Message Count:
    1,023
    Lexington, Ky
    to get my 289 heads cleaned up, putting bigger stuff in them, or gettin some heads off an explorer and giving them a bath and new valves?
  2. allcarfan The Answer Man
    Apr 8, 2001
    Message Count:
    3,755
    56
    North Atlanta
    score the gt40p heads
  3. krash kendall New Member
    Nov 20, 2004
    Message Count:
    1,264
    Aldergrove, B.C. Canada
    Won't he have to get new headers again if he goes to the "P" heads?
  4. Cobain03 New Member
    Aug 27, 2003
    Message Count:
    1,023
    Lexington, Ky
    whoa, no one told me bout that. please explain
  5. Cobain03 New Member
    Aug 27, 2003
    Message Count:
    1,023
    Lexington, Ky
    can anyone clarify?
  6. krash kendall New Member
    Nov 20, 2004
    Message Count:
    1,264
    Sorry, I just remember this coming up in an earlier thread that the gt40P and the gt40 heads require different exhaust due to, I believe, a sending unit port. I only pointed it out because I remember the ongoing saga with you header p/s conflict and wouldn't want to see you go through that again if it wasn't neccessary.
  7. krash kendall New Member
    Nov 20, 2004
    Message Count:
    1,264
    I found it!!!
  8. 65fastback2+2 New Member
    Aug 4, 2003
    Message Count:
    1,239
    Louisville, KY
    the front exhaust pipe on tri-y's on the left cylinder head will not clear the spark plug...if you are good at welding and can splice in an extra 2 inches of pipe into it...then they will work fine...they clear the right head fine.
  9. Cobain03 New Member
    Aug 27, 2003
    Message Count:
    1,023
    Lexington, Ky
    i AM NOT messing with those god forsaken headers. what you think buot 351 W heads?
  10. krash kendall New Member
    Nov 20, 2004
    Message Count:
    1,264
    I didn't think you wanted to, that's why I thought I'd better give you the vague information yesterday. Sorry it took so long to find the actual facts.
  11. Cobain03 New Member
    Aug 27, 2003
    Message Count:
    1,023
    Lexington, Ky
    no problems. i got a lil bit before i start payin for stuff. thanks!
    so now that gt40s are out of the question....
  12. rbohm Founding Member
    Apr 13, 2002
    Message Count:
    4,770
    68
    tucson,az/luray,va
    go get a set of windsor jr heads. they will use your same headers with no problem, and will add more power than even the gt40 heads will. they also use chevy valves 1.94in/1.60ex so parts are readily available, and inexpensive.
  13. Cobain03 New Member
    Aug 27, 2003
    Message Count:
    1,023
    Lexington, Ky
    those are expensive too
  14. Max Power New Member
    Jul 31, 2003
    Message Count:
    1,776
    St Paul
    It costs money to make horsepower.
    If you get say, a set of 351w heads, and do what you need to make them work in todays world, like thermactor porting, hardened seats, screw in studs, 3 angle valve job, etc, you will easily spend what it costs to get a decent set of aftermarket heads like Windsor Jrs.
  15. 65fastback2+2 New Member
    Aug 4, 2003
    Message Count:
    1,239
    Louisville, KY
    find some 93 cobra GT40's
  16. krash kendall New Member
    Nov 20, 2004
    Message Count:
    1,264
    As far as I know only the "P" heads have the relocated spark plugs. The regular gt40s should be fine.
  17. slepe67 New Member
    Mar 31, 2005
    Message Count:
    78
    So (hitchhiking again here), if a guy gets the Windsor Jr heads, what mods have to be done to get them to work on a 289?
Share This Page
