@%@^&$!! Wheel hop??
Discussion in '2005 - 2009 Specific Tech' started by ptfoxbdy89, Oct 8, 2008.
  1. ptfoxbdy89 New Member
    Aug 4, 2007
    Message Count:
    137
    ok if any of you have seen me post last week you would see that i have had plenty-o-troubles with my new 2005 mustang gt.. its got only 15000 miles on it and i have had my share of troubles with it withing two-weeks.. anyway this morning im leaving out of a gas station and i have tcs off im possitive because the light was illuminated on the center display. Anyway i make a right turn.. the road is wet and i wanna slide the rear around a little so i slip the clutch and pull out.. about halfway out into the road when the rear wheels should be spinnin the car begins to vibrate abruptly i let out of the throttle and the vibrations stop..??? I have been in many of cobra with the ole wheel hop syndrome and thats what it felt like!! any ideas?? i didn't hear any noise from the rear end on the rest of the drive? help!!
  2. fasterthanthem New Member
    Mar 30, 2008
    Message Count:
    62
    Could be any number of things. The road may not have been as wet as you thought. The road could have been uneven. Your tires were catching traction.. just cause they can.
  3. ptfoxbdy89 New Member
    Aug 4, 2007
    Message Count:
    137
    ok i just didn't know i've heard some spooky things about the 8.8s in the late model mustangs so you think im ok for even the dash board getting the vibrations.. seriously it felt like a 12 second launch lol guess i'm just a little paranoid what with all the other troubles ive had.. thanks for the imput!
  4. CPman New Member
    Apr 3, 2005
    Message Count:
    129
    It's just the nature of the beast. I think everyone has had this condition at one time or another. Changing the upper and lower rear control arms to units that are more rigid and with stiffer bushings will make this go away. Everything is soft in the rear suspension so you don't feel the road, and you will feel it a little bit more (not much difference at all) with aftermarket componants, but the improvment in hard launches and overall drivability is well worth it.
  5. ptfoxbdy89 New Member
    Aug 4, 2007
    Message Count:
    137
    well said ill look into it but would changing the suspension components void my warrenty?
  6. xxrequiemxx New Member
    Aug 24, 2001
    Message Count:
    239
    I had a lot better traction once I got my eagle F1 tires on... Not sure if that helps
  7. NastyStang113 New Member
    Sep 12, 2008
    Message Count:
    1,591
    What tires do you have?
  8. ptfoxbdy89 New Member
    Aug 4, 2007
    Message Count:
    137
    i deff got traction i think thats why it wheel hopped like that... i have i'm assuming factory pnerozero 235/55/r17s and the car is bone stock..
  9. gmantheman New Member
    Dec 30, 2007
    Message Count:
    492
    Besides new tires, start with LCA. After installing steeda LCA, wheel hop was not completely eliminated, but it was reduced. My 60' times improved by an avg of .2 sec.
  10. hotrodnut Member
    Jul 12, 2004
    Message Count:
    672
    It is wheel hop, it seems worse in the rain. As mentioned, it's the softer bushings in the control arms that are mostly the cause. Some is generated from the stamped lower control arm construction but mostly from the control arms rubber bushings.
    The lowers do help as mentioned, but that does not totally eliminate it either. The upper has to be replaced too, and I suggest going with an adjustable one for that. I got caught buying non-adjustable uppers on the Mach1 and later when I lowered it I needed to get the adjustable to get my pinion angle back in sync.
    I bought mine before I got my Bullitt and still haven't had a chance to mount them up. I'm chompin' at the bit to drop the hammer on it too but don't want to until I get the good control arms on.
  11. The Shape Founding Member
    Jan 11, 2002
    Message Count:
    2,207
    What ended up being the cause of your coolant leak?
  12. ptfoxbdy89 New Member
    Aug 4, 2007
    Message Count:
    137
    hey lol you guys do remember.. from what i could tell the overflow resevoir had a hairline crack in the threads.. i'm assuming even in the overflow there is still some pressure so i could see that.. i went back to the dealership said they had two options 1. to try my size 11 1/2 up the arse on or 2. go out to one of the 2009 mustangs pull one off and put it on mine! 30 min later i got my car back and not a drop since then so its looking pretty good..
    on another note.. you guys think i should get some upper and lower control arms (adjustable of coarse.. thanks for the heads up) before visiting the track..:( i just wanted to see what she would do stock and work my way up, my funding towards aftermarket parts isn't what it use to be what with the economy all jacked up and stuff.. and what is a good all around tire i have pretty mild winters here so snow isn't ever a problem im def not buying slicks though this is my daily driver..
  13. hotrodnut Member
    Jul 12, 2004
    Message Count:
    672
    I would not go without them, because of the wheelhop, most tracks it's worse than the street because of the grip juice put on the track.
    I broke some parts in the past from violant wheelhop, not sayng that the newer Mustangs aren't strong enough, I just wouldn't chance it.
    I got the following at a resonable price:
    1. J&M Products Mustang 2005+ Street Lower Control Arms
    2. J&M Products Dbl Adjustable Mustang 2005+ Upper Control Arm
    These were around $250 from a place here in FL, you may get them all for less looking around.
    I might go to the track before, I would just launch without dropping the clutch, sort of a little slip and punch take-off, that way the tires probably won't bust loose and start wheel hopping.
  14. ptfoxbdy89 New Member
    Aug 4, 2007
    Message Count:
    137
    ok thanks for the advise your right i would rather pay $250 and install them myself then try to explain to the dealership why AAA had to tow my car from the track the the rear end was demolished!! by the way would i be able to install the control arms myself.. i have plenty of tools and im semi mechanically inclined.. lol i don't change my blinker fluid often enough though;)
  15. CPman New Member
    Apr 3, 2005
    Message Count:
    129
    For sure get your UCA and LCA replaced before going to the track or you will end up just beating your car to death with wheel hop.
  16. NastyStang113 New Member
    Sep 12, 2008
    Message Count:
    1,591
    I had the same problem in the rain with the factory tires. I switched to Nitto555s and had zero problems in the rain ...
  17. ptfoxbdy89 New Member
    Aug 4, 2007
    Message Count:
    137
    really?? that sucks you would think they would not put complete crap on the wheels right out of the box.. ill look around for some different tires
  18. hotrodnut Member
    Jul 12, 2004
    Message Count:
    672
    Although the Factory tire may be crap compared to the Nitto555's, actually it is somewhat better in the wet. The Factory tire is an MS tire as the Nitto555 is an ultra highperformance summer tire. It probably doesn't quite get the wet traction the Factory tire does so therefore you don't get the wheelhop.
    Yes I would still prefer the Nitto555 over the factory tires because of the superior dry traction levels.
  19. hotrodnut Member
    Jul 12, 2004
    Message Count:
    672
    I would say yes you can install them yourself. You will need jackstands of course to support the car and I use my floor jack to support the differential while lining up the bolt holes in the control arms. Do one side at a time and then the upper by itself, that will make it eaiser to line up.
  20. autumn_again New Member
    Oct 3, 2007
    Message Count:
    365
    yeah i'm suffering from wheel hop too. i ordered the LCAS from cjpony parts, said they were shipping em 2 days ago, so we shall see when they get here when i launch it.
    i'm also thinking of going as far as the anti roll bar. i loved the fact with my old stang i could just give it some revs, dump the clutch and take off in a cloud of smoke.
Share This Page
