where is it ??
Discussion in '2.3L (N/A & Turbo)' started by Ponycar, Feb 25, 2004.
  1. Ponycar Founding Member
    May 4, 2002
    Message Count:
    90
    :shrug: I have a 93 convert 2.3, where is the fuel pump relay??, on my 89 it's under the drivers seat. I'm gonna splice into the hot wire with a switch as a cheap anti theft device..thanks
  2. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    It's in the IRCM on the passenger side strut tower (big black box).
  3. Ponycar Founding Member
    May 4, 2002
    Message Count:
    90
    :notnice: guess that kills my idea, any suggestions??
  4. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    You can still do it...just gotta use hit the right wires.
    It is just a box with 4 or 5 relays wired into it.
    Stinger
  5. Ponycar Founding Member
    May 4, 2002
    Message Count:
    90
    :shrug: anybody know which wires to cut???????
  6. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Here, this should tell you:
    [IMG]
    [IMG]
  7. Ponycar Founding Member
    May 4, 2002
    Message Count:
    90
    Thanks Guys, will give it a try. put a heater coil into my coupe this weekend, found out that the dealer installed alarm wiring won't let the car start when I cut it!!. Took a dremel and cut the coil box out enough to remove the coil without disturbing the entire assembly, man what a job!!..got it all fixed up and put back together
Share This Page
