Wicked Wheel Hop
I own an 05' GT, stick no mods yet and want to know what the best cure for wheel hop would be? I have already tried traction control on and off, off seems to help a little but still get wheel hop, even in the rain.
I have heard that once you add a tune and CAI it is less of a problem due to more power = more wheel spin, I have also heard that LCA's would cure the problem. Any input from someone with same problem and either of these mods? Did it help / cure problem?
Thanks
More power causes less wheel hop? is that true? When I added more power to mine it had crazy wheel hop. I solved the problem by easing into the throttle and mashing it when I felt it catch traction. Of course a set of control arms would make it all disappear. When I drove my friends stock 05, I didnt even notice it. I would think with a higher torque curve it would not be as noticeable as my 5.0 which had insane wheel hop, especially with 4.10's.
More torque = more wheel hop (also depends on the stickiness of the tires). When I had the 4.10s and Steeda Pulleys installed, I hopped on 1st AND 2nd gear.
Red Pony said:
Did you ever resolve the wheel hop you are getting or just living with it. If you corrected it, what did you add?
I will be ordering the BMR Lower Control Arms with poly bushings along with the relocation brackets soon. This should take care of my wheel hop.
