window problem covered under warranty or not
Discussion in 'SN95 4.6 Talk' started by dastang2, Apr 3, 2007.
  1. dastang2 Active Member
    Dec 12, 2003
    Message Count:
    2,058
    46
    i have a 2000 convertable and i just had to replace the window in it. it was working good for a while but now it keeps going crooked when lowered. it also pops. i think the rollers came out of the rails. i am going to lube the rail up good and try it but if it doesn't fix the problem will this be covered under my extended warranty. is everything in the door covered. i did try to adjust the rails using the torx studs and set nuts on the rail.
  2. Kilgore Trout Fried or Broiled ?
    Mar 31, 2005
    Message Count:
    8,280
    76
  3. dastang2 Active Member
    Dec 12, 2003
    Message Count:
    2,058
    46
    do you think a regulator is under warranty. are the wheels on the window supposed to come off when pulled, because i think that is what happened. it may have popped off the wheel. it went up just fine for a few weeks and then this.
  4. Kilgore Trout Fried or Broiled ?
    Mar 31, 2005
    Message Count:
    8,280
    76
    Damn, I thought you meant you replaced the REAR WINDOW and the TOP ITSELF was going up crooked... Sorry about that :(
    Sounds like you need a new window regulator. I made a thread on replacing this in 4.6 tech with pics and parts prices.
  5. tomustang Psychotic Member
    Jun 8, 2000
    Message Count:
    5,018
    76
    check the rails, if they are bent out of shape it wont be long till they mess up the rollers and everything else, when I fixed my window from the same thing that happened to you I rebent the rails to make it work
  6. fatboy02gt New Member
    Mar 26, 2007
    Message Count:
    11
    samething just happened to mine. had to pay 800 bucks to replace the glass. ford extended warranty paid for the regulator. :mad:
  7. twogts4us Advanced Member
    Apr 2, 2004
    Message Count:
    4,084
    68
    seems to be a not-so-uncommon issue with the gen2 sn-95. My wife's had the same issues...and now, the window has come unglued - causing the crooked rise and rising too far.
  8. Mike97gt it doe snot
    Jan 26, 1999
    Message Count:
    12,475
    76
    depends on the warranty, there is thousands of different extended warranties out there..
Share This Page
