Wiring
Discussion in 'Fox 5.0 Talk' started by shewitt, Sep 29, 2007.
  1. shewitt New Member
    Aug 19, 2003
    Message Count:
    125
    Newnan GA
    How hard is it to hide all the wires in the engine compartment. Mostly the ones coming from the driver side. Do you put them all in the fender and do you have to cut and splice them.
  2. ryan218 In just 10 years, I'll be old enough to drive!!!!
    Dec 29, 2005
    Message Count:
    214
    27
    38
    columbus ohio
    yeah...you have to extend them and you tuck them in the inner fender
  3. ALMOST STOCK Founding Member
    Sep 23, 2000
    Message Count:
    1,245
    36
    CA.
    It's not hard at all to put the wires in your fenders, my guess is that it might take you 4 hrs or so to put all the wires in the drivers side fender and less than 2 hrs to put all the wires in the passenger side fender.
    Hiding vacuum lines probably an hr, and hiding brake lines probably 3 hrs if the engine is out, believe me none of this is hard.
    I put my wires in the fenders over 7 yrs ago and I never cut and extended a wire in the process other than the Over Flow bottle and the A/C compressor wire and had I not welded up all the holes in the engine bay I'm not sure if I would of had to cut and extend those wires.
    Drivers Side
    [IMG]
    [IMG]
    Passenger Side
    [IMG]
Share This Page
