your thoughts please
Discussion in '94-95 Tech' started by BlackVert, Oct 26, 2004.
  1. BlackVert Mustang Master
    Oct 3, 2003
    Message Count:
    5,575
    78
    i recently installed a used stock fuel pressure regulator. i have the stock maf back in. and i have stock injectors.
    i set my high and low slopes back to stock (28.8/19.64). the kamrfs were around 1.15. i have lowered them both gradually. the high slope is now 17, low is 26. it is still lean, but not as lean.
    i am thinking it must be one of:
    (1) fpr is bad
    (2) fpr was dirty or rusty, injectors and/or fuel filter are now clogged
    (3) vacuum tube from intake to fpr is not very tight, not enough vacuum
    any other thoughts?
  2. BlackVert Mustang Master
    Oct 3, 2003
    Message Count:
    5,575
    78
  3. mytight95 New Member
    Apr 11, 2003
    Message Count:
    2,609
    the reg is good........i assume you changed the values with the tweecer or something.........
    :shrug:.........
    only thing i can think of is if the car has mods.......you may need more pressure....PUMP.........or that the filter is clogged.......pump could be going bad....................hey man e-mail me what it is doing....mytight95@msn.com..........are you checking the pressure with the vacuum off..............
    jason
  4. BlackVert Mustang Master
    Oct 3, 2003
    Message Count:
    5,575
    78
    ever run out of gas? it acts like it is on the verge of running out of gas.
    it was much worse on the way home.
    - i believe that the fpr is not bad
    - yes i changed the values with my tweecer.
    - my mods are not nearly extensive enough that there is no possible way i am maxxing out the injectors. the highest duty cycle i have seen is like 15%.
    - could be the pump - good point
    - i need to dig up my fuel pressure gauge and hook it up.
  5. mytight95 New Member
    Apr 11, 2003
    Message Count:
    2,609
    yeah i would do that.............with the gauge............i would guess that the pump is going bad or the filter is clogged if you are only seeing 15% duty cycle...................
    you need to check the pressure.......check the filter etc. i think.................try and run it without vacuum on the reg.........block off the vacuum line from the intake.......drive it.........see how it does..............
    jason
  6. BlackVert Mustang Master
    Oct 3, 2003
    Message Count:
    5,575
    78
    stupid question time: will taking the vac line off increase the pressure or decrease it?
  7. BlackVert Mustang Master
    Oct 3, 2003
    Message Count:
    5,575
    78
    ok, i got the answer to this one: the pressure will go up.
    another question: after replacing the fpr, do you need to do anything to get the air out of the fuel lines?
  8. HISSIN50 "How long do you think it'll take me to get any he
    Jul 2, 2003
    Message Count:
    30,794
    76
    prime the pump. :D
    the system flows enough pressure to purge the system of air (unlike old low pressure mech pumps).
    good luck.
Share This Page
