Absolutely, so long as you are talking about the 94-95's. The earlier years OBDI had 2 digit code though.
O= KOEO
R= KOER
M= memory, continuous
111 - System Pass
112 - ACT Sensor Circuit Below Minimum Voltage of 0.2 volts (O), ACT circuit has intermittently failed below minimum 0.2 volts (M)
113 - ACT Sensor Circuit Above Maximum Voltage of 4.6 volts (O), ACT circuit has intermittently failed above the maximum of 4.6 volts (M)
114 - ACT out of self test range 0.3 to 3.7 volts
116 - ECT out of self test range 0.3 to 3.7 volts
117 - ECT Sensor Circuit Below Minimum Voltage of 0.2 volts(O), ECT circuit has intermittently failed below minimum 0.2 volts (M)
118 - ECT Sensor Circuit Above Maximum Voltage of 4.6 volts (O), ECT sensor circuit has intermittently failed above the maximum of 4.6 volts (M)
121 - Closed throttle TPS voltage higher or lower than expected (O,R), TP sensor was inconsistent with the MAF/MAP value in the last 80 drive cycles (M)
122 - TPS circuit below minimum 0.6 volts (O), TPS circuit has intermittently failed below minimum 0.6 volts (M)
123 - TP circuit above maximum 4.5 volts (O), TPS circuit has intermittently failed above maximum 4.5 volts (M)
124 - TP sensor was higher than expected with the MAF/MAP value in the last 80 drive cycles (M)
125 - TP sensor was lower than expected with the MAF/MAP value in the last 80 drive cycles (M)
126 - MAP/BP sensor out of self test range 1.4 to 1.6 volts
128 - MAP sensor vacuum was not greater than 2 in-Hg (7 kPa) during normal vehicle operation
129 - Insufficient MAF/MAP change during Dynamic Response Test
136 - o2 Sensor circuit indicates system lean (left side)
137 - o2 Sensor circuit indicates system rich (left side)
139 - No HEGO sensor switching detected or disconnected (left side)
141 - o2 Sensor circuit indicates system lean (both sides)
144 - No o2 Sensor switching detected or disconnected (right side)
157 - MAF sensor went below 0.4 volts during the last 80 warm-up cycles
158 - MAF sensor went above 4.5 volts during the last 80 warm-up cycles
159 - MAF signal was greater than 0.70 volt during KOEO (O), MAF signal was not between 0.20 and 1.50 volts during KOER (R)
167 - TPS did not exceed 25% rotation during the Dynamic Response Test
171 - Fuel system at adaptive limit, o2 Sensor unable to switch (right side)
172 - o2 Sensor sensor circuit indicates system lean (right side)
173 - o2 Sensor sensor circuit indicates system rich (right side)
174 - o2 Sensor switching time is slow
175 - Fuel system at adaptive limit, o2 Sensor unable to switch(left side, (Bank No. 2))
176 - o2 Sensor circuit indicates system lean (left side)
177 - o2 Sensor circuit indicates system rich (left side)
178 - o2 Sensor switching time is slow (Bank No. 1)
179 - Right side still rich, at leanest adaptive limit, during part throttle
181 - Right side still lean, at richest adaptive limit, during part throttle
182 - Right side still rich, at leanest adaptive limit, at idle
183 - Right side still lean, at richest adaptive limit, at idle
184 - MAF higher than expected
185 - MAF lower than expected
186 - Injector pulse width longer than expected
187 - Injector pulse width shorter than expected
188 - Left side still rich, at leanest adaptive limit, during part throttle
189 - Left side still lean, at richest adaptive limit, during part throttle
191 - Left side still rich, at leanest adaptive limit, at idle
192 - Left side still lean, at richest adaptive limit, at idle
193 - Flexible Fuel sensor circuit failure
194 - Run cylinder balance diagnostic test
195 - Run cylinder balance diagnostic test
211 - Two or more successive erratic Profile Ignition Pickup (PIP) pulses occurred, resulting in a possible engine miss or stall
212 - Loss of IDM (Ignition Diagnostic Monitor) input to EEC or SPOUT circuit grounded
213 - SPOUT circuit open
214 - Cylinder Identification (CID) circuit failure
215 - EEC detected coil 1 primary circuit failure
216 - EEC detected coil 2 primary circuit failure
217 - EEC detected coil 3 primary circuit failure
218 - Loss of IDM (Ignition Diagnostic Monitor) signal (left side)
219 - SPOUT failure, spark timing has defaulted to 10 degrees BTDC
222 - Loss of IDM (Ignition Diagnostic Monitor)signal (right side)
223 - Loss of Dual Plug Inhibit control
224 - Erratic IDM (Ignition Diagnostic Monitor)input to processor
225 - Knock Sensor (KS) signal not sensed during dynamic response test
226 - IDM (Ignition Diagnostic Monitor)signal not received
244 - Camshaft Position (CMP) Sensor failure
311 - Thermactor air system inoperative (right side)
312 - Thermactor air misdirected upstream during self test
313 - Thermactor air not bypassed during self test
314 - Thermactor air system inoperative (left side)
326 - PFE or DPFE circuit voltage lower than expected with zero EVR duty cycle
327 - DPFE or EVP circuit below minimum voltage of 0.2 volts
328 - EVP circuit below minimum voltage of 0.24 volts
332 - EGR valve opening not detected
334 - DPFE or EVP circuit above the closed limit of 0.67 volts
335 - PFE or DPFE sensor voltage out of Self-Test range
336 - EVP or DPFE circuit voltage above maximum voltage with zero EVR duty cycle
337 - DPFE or EVP circuit above the maximum limit of 4.81 volts
338 - ECT lower than expected
339 - ECT higher than expected
341 - Octane Adjust shorting bar is not in or the OCT ADJ circuit is open
381 - Frequent A/C compressor clutch (ACCS) cycling less than 8.5 seconds
411 - Cannot control rpm during KOER low RPM check
412 - Cannot control rpm during KOER high RPM check
452 - Computer detected an error in the VSS or PSOM signal during the last 80 warm-up cycles
461 - Engine over speed was detected
511 - EEC permanent Read Only Memory (ROM) test failed
512 - EEC battery powered Keep Alive Memory (KAM) test failed
513 - Failure in EEC processor internal voltage
519 - Power steering pressure switch circuit open
521 - Power steering pressure switch did not change state during KOER test
522 - Vehicle not in PARK or NEUTRAL during KOEO
524 - When the PCM commanded the fuel pump on, voltage was not detected on FPM
525 - Vehicle in gear or A/C on during Self-Test
526 - Neutral Pressure Switch closed or A/C on
527 - Neutral Drive Switch open or A/C on
528 - Clutch Switch Circuit failure
529 - Data Communications Link or Electronic Instrument Cluster circuit failure
532 - Data Communications Link or Electronic Instrument Cluster circuit failure
533 - Data Communications Link or Electronic Instrument Cluster circuit failure
536 - Brake On/Off circuit failure / switch not actuated during KOER test
538 - Insufficient RPM change during KOER dynamic response test/ Operator error
539 - A/C or Defroster ON during KOEO test
542 - Fuel pump circuit failure
543 - When the PCM commanded the fuel pump on, voltage was not detected on FPM
551 - Intake Manifold Runner Control (IMRC) circuit failure
552 - Air management 1 circuit failure (AM1/TAB)
553 - Air management 2 circuit failure (AM1/TAD)
554 - Fuel Pressure Regulator Control (FPRC) solenoid circuit failure
556 - Fuel Pump circuit failure
557 - Fuel pump relay coil resistance failure
558 - EGR Vacuum Regulator circuit failure
559 - Air Conditioning On relay circuit failure
563 - High Speed Electro-Drive Fan circuit failure
564 - Electro-Drive Fan circuit failure
565 - Canister purge circuit failure
566 - 3 ? 4 Shift Solenoid failure
569 - Canister purge 2 circuit failure
571 - EGR Atmospheric Regulator circuit failure
572 - EGR Vacuum Regulator circuit failure
578 - A/C Pressure (ACP) sensor VREF circuit is short to ground
579 - A/C Pressure (ACP) sensor circuit is above maximum voltage
581 - When the cooling fan was activated, the circuit exceeded current draw
582 - Open or short to power in the power-to-cooling fan circuit
583 - When the fuel pump was activated, the power-to-pump circuit exceeded the normal current draw
584 - Variable Control Relay Module circuit grounded
585 - A/C clutch circuit exceeded the normal current draw
586 - A/C clutch circuit open or shorted to power
587 - Data Communications Link (DCL) error
593 - Oxygen Sensor Heater circuit failure
617 - 1 - 2 shift error (E4OD)
618 - 2 - 3 shift error (E4OD)
619 - 3 - 4 shift error (E4OD)
621 - Shift solenoid #1 circuit failure
622 - Shift solenoid #2 circuit failure
623 - Overdrive light circuit failure
624 - Electronic Pressure Control solenoid or driver circuit failure
625 - Electronic Pressure Control driver open in EEC
626 - Coast clutch solenoid circuit failure (E4OD)
627 - Converter clutch solenoid circuit failure (E4OD)
628 - Converter clutch Lock-Up error (E4OD)
629 - Converter clutch control circuit failure
631 - Overdrive light circuit failure
632 - Overdrive cancel switch not changing state (E4OD)
633 - 4WD switch is closed
634 - Transmission Manual Lever Position Sensor circuit out of self test
636 - TOT sensor voltage out of self test range
637 - TOT sensor circuit above maximum voltage
638 - TOT sensor circuit below minimum voltage
639 - Insufficient input from the Transmission Speed Sensor
641 - Shift solenoid #3 circuit failure
643 - Converter Clutch Control circuit failure
645 - Incorrect gear ratio obtained for first gear
646 - Incorrect gear ratio obtained for second gear
647 - Incorrect gear ratio obtained for third gear
648 - Incorrect gear ratio obtained for fourth gear
649 - Electronic Pressure Control range failure
651 - Electronic Pressure Control circuit failure
652 - Modulated Converter Clutch Control solenoid output circuit error
653 - Transmission Control Switch was not cycled during KOER Self-Test
654 - MLP sensor not in park position
656 - Converter Clutch Control continuous slip error detected
657 - Transmission over temperature condition occurred
659 - High vehicle speed detected while the vehicle was in PARK
667 - Transmission Manual Lever Position Sensor circuit shorted
668 - Transmission Manual Lever Position Sensor circuit open
675 - MLP circuit voltage was out of the expected range
691 - 4WD switch circuit failure
998 - Hard fault present
