I'm the original owner of a '93 Cobra I bought as a "company car". [good to own the company] It was my daily driver in the N.E. for about 6 years then a Friday night / Sunday car for another 8-10 years, then it sat. I think I put 200 miles on it since. It was usually in the garage, covered, but depending on what project was in the garage it sat outside covered. [I know]
So now it's the current project.
Amazingly after sitting for 2-3 years it started right up, [battery tender] but the drivers seat and headliner is shot and under the hood is fuugly.
The smog pump was stuck, and in taking that off, noticed a drip from the water pump, so everything came off the front of the engine.
You can probably see where this is going, but I've at least resisted the urge to pull the engine.
I'm in the throws of an under the hood restoration, and have most of the lines and all the 'stuff" that is on the firewall and the inner fenders removed. One little spot of rust, surface type on the frame under the battery tray, so I lucked out there.
Anyway, first question.
Has anyone found a good match for the oem paint on the upper intake? I know some were bare but my Cobra was a grey-ish color with little or no metallic.
Thanks,
rob j
Thanks,
rob j
