My only question on the meth - Is it going to use such an amount that it isnt reasonable? Cost isnt an issue, but are you having to stop and fill up the tank every 50 miles versus every fill up?
See,..this is how I see it, and where I sit on the fence about the whole water/meth intercooler path over conventional intercooling...
Right now..on a 90 degree day...my IAT shows to be about ambient.. ( as it should, the water in the intercooler will be the same temp) when I stand on it the temps will raise about 20 degrees..and will quickly cool back down to ambient when the IC is running..there's a 3 gallon reservoir full of antifreeze and a Cobra pump, moving water from front to back,...and through a set a fan cooled radiators keeping all of that copacetic.
The point to the above is that even w/o the IC running,.the temps only went from 90 to 110...
If I added a water meth system it'd have a 1 gallon reservoir w/ a low level light when it gets low..id only use it for boost numbers above 7 psi.
Therein lies the beauty of my MSII.....if I can figure this thing out..
The water meth will only be activated at XX pounds of boost...( wherever the engine rattles) let's say that's "8.5 psi"
There should be some programmable output in my MSII that could be tied to that chore..
As a fail safe, when that low level light in the water meth reservoir gets triggered, I should also be able to send an input signal to my MSII that says " Hey! Dumbass! No more high boost" and tells the EBC to back off to a duty cycle that will not allow for more than WG pressure, which will be 7psi.
Now....my question ( to myself) is......
If the water meth only triggers at 8.5 pounds..how long will one gallon last? I mean it's not like I drive around with my foot on the floor all the time in this car..If my IAT's do in fact only rise 20 degrees w/o that IC running,..
Why do I need all of that crazy Mad Scientology?
How much cooler will the IAT go when there is a mist of water meth being sprayed into the engine?
How much longer will the water meth last if I repurpose that 2.5 gal reservoir that's full of antifreeze, and filled it with windshield washer fluid instead?
