this may sound like a dumb question to some of you. are there any differences in the 5.0L engines installed in the 94-95 model years than the earlier year 5.0L motors? besides the obvious upper intake elbow.
thanksIt is not a dumb question, I'm just not sure about the answer, I don't think there is, I'll get some experience in here and both of us can find out for sure.
@a91what / @74stang2togo
are the mounting points the same of I were to use accessories from my 95 motorWater pump,timing cover and accessory’s I believe are different
The 94/95 had an electric fan, while the earlier ones had a belt driven fan clutch. The shorty headers were different for the 94/95 cars due to an external EGR tube going to the passenger side header. Internally, pretty close to the same. Camshft specs slightly different, different V/C as well. Stamped steeel instead of cast aluminum.
Edit: Dist was different, had remote TFI module.
Yes, use the 94-5 timing cover
so the other question I have is can i take a modified 5.0L previously in a fox body mustang and install it in my 95. are there any modifications?
top end..gt40 upper and lower intake, not from explorer, gt40 heads, f303 cam, stock bottom end. will need elbow for intake. I think it also has 1.6 roller rockers.I don’t see why not- what kinda mods are done to the Fox 5.0?
Google is my best friend! [/QUOTLets see, turbo (not all turbo's come with jack stands so check with the manufacturers)
Explorer intake?
The usual things. (I see you got a gt40 intake, good deal)
What are go going to do with it, daily driver, weekend beat up on random imports or track
Yes it will all swap over
You’re a knowledgeable dude-And pretty funny lol
Google is my best friend! [/QUOTE]Lets see, turbo (not all turbo's come with jack stands so check with the manufacturers)
Explorer intake?
