Guys who run haltech and even aem tune speed Density with themVvt is no issue if you tune in MAF. Otherwise it's just setting up dual tables for in/out of vvt
I did some wiring on this car for him fixed a bunch of stuff it’s a really cool car . Full interior , all windows work power looks , radio etc . It was a drift car made nice and converted back into a street cruiser^^^^^^THIS!!!^^^^^^^IS WHAT IM TALKING ABOUT!!!
We put one in a 86 coupe as well . Idk who pissed in your Cheerios but to each his own . 2js have been real fast .I should have stopped at 333 posts like I intended. W@nkers the lot of you. What kind of f!-!|《t@rd even contemplates putting a Toy Motor into a FoMoCo product. My last 7 Toyotas have been purile, souless and engineering retarded "monstrocities" that make reast in the Nostramo awaiting an alien attack a prefference to this Hell Hole. Time to go for me. I feel like Frank Zappa when his audience partipation test reveals 100% are morons.
Yes dual tables is for speed density, you can do without it if the ecu controls the vvt activation. For the setups that have vvt by oil pressure only it's best to switch to a vvt table. Err ah my brain likes it better that way, I'm picky.Guys who run haltech and even aem tune speed Density with them
Buschur racing did a 4g63 32 ford as well . I’m a car guy I love fast stuff and Dable in it all !Turbo Toyota 2JZ Powered 1931 Ford Model A
Brandon DeJesus rolls a '31 Ford Model A rat rod that's powered by Toyota's 2JZ-GTE power plant that's so ready to make staggering horsepower.m.roadkillcustoms.com
Mike I love hearing like this . I hope it stays this wayOk,...Just got back after an auto tune,....and a full pull off of auto tune...
Ahem...
Without the freakin boost duty controller doing a damn thing..I now have exactly 10 p.s.i. of boost. Clearly the spring that is in this new waste gate is a 10 pounder.
This whole time that I've had this setup ( new Chinee turbo, new waste gate, ITB's) That ITB "hat" has been leaking boost like a bitch.
10 PSI before left the engine a freakin oily assed disaster but this time around,..courtesy of the new Puke Troll...
clean as a whistle.
So,...provided I haven't hurt anything ( which I haven't,...the pull was as clean as you could ask for) it's time to ramp up the EBC..IIRC, nothing happened with that thing till the controller was set to 50% .....page 297 tells that tale..
It's clean, It's waxed, nothin left to do but drive it. Think I'll take it to the Mccalla cruise in.
p.s....... for those that care.
Don’t be so stupid Noobz, they can’t BOTH be 1JZ! One must be 2JZ.........
Seems legit
It’s not addition, you just need 2JZ, 1JZ can leave. That would look stupid in the engine bay anyhow.
I like the new wheels Mike. The Monster looks sweet.And we arrive w/o incident
I didn't take my computer with me. I need to open the throttle screw some more though,..it doesn't like the current setting.you have a datlog of the surge? Likely its because the engine was truly heat soaked, if you have a datalog i can see what i can do about that issue.
All I know is that when I Googled to see if it was possible, that this is what turned up.
So... All I know is that someone else has already done it and the proof is in the image above.
So get off my back! The interwebZ doesn't lie.
Well one way or the other...the surge was huge after bringing the car down my driveway, but the engine was also over 200 degrees...it really concerned me. I just went down there, pulled all six plugs,..they're all perfect. I cracked the throttle screw and fired it up. It wants more air at idle..it is running at 1000 rpm at idle, and happy. I don't mind that. Tomorrow, I'm gonna add the timing back in, and correct the throttle back out of it slightly.Looking at the datalog you posted above it seems like the car wants a slightly higher idle speed, with no idle valve this can be difficult. before you mess with the idle screw i would try increasing the Idle advance timing from 20 to 25. your combo seems to like slightly higher idle timing.
Don't apologize, aside from the coil packs on the valve cover, and the obvious dual cam gears, that engine looks a lot like mine.I'm gonna tap you as a source for info when I get closer to the end of the year. When you google 2jz engine for sale, there are several importers that pop up with pics of engines out of Japanese Lexus models that aren't sold here. If you can tell me what to look for as a starting point,..ill buy one of those engines.Sorry mike I’ll stop after this .
We did this over 2-3 years ago in my buddies 86 which just got re done with a 10:1 version . We have been doing that car prob over 5-6 years now I helped him prep to paint , mock engine up to make mounts etc .
Also another friend here has a reef notch with a 2j.
8 years ago someone on supra forums did a mint white coupe in Cali.
Body work will be finished this season . Reason he didn’t paint nose was because he didn’t want to keep making changes and risk the paint . Rest is mint . Gas door even shaved cuz it has a cell . We did this whole car including assy the first engine in his over size 1 car garage . Mini tub , all body work , 3/4 of the paint , cage , interior , haltech wiring you name it .
@Noobz347
