I need some clarity on the clutch safety switch system on an 01 with t5. I need my car to not be able to start in gear with clutch out. Right now it will start in gear without the clutch depressed. Its kinda backwards from all the problems ive been searching so far it seems everyone posts their car wont start at all the switch is defective. But i literally cant get it to not crank while its in gear. Im thinking short or bypassed from previous owner ? I will admit hes was hack and ive spent several hours putting things back to normal, For example he tapped in to the wiper 12v ignt on for his stereo. Im also reading the neutral safety switch (on t5 itself) only talks to the ecm and not connected to the starter relay. So this should only be ignt to clutch safety to start relay ?
This was a v6 car if you need details but its Not anymore but the ecm and all relative systems were kept running
Reason I care is for tech inspection !
Thanks
Anthony.
Thanks
Anthony.
