Since the car was swapped from aod to t5 I guess what I'm asking is.... what needs to be done or added for the cruise to work. Guy that built it says one plug needs to be added/ hooked up and it should work. I don't know. I can work on a lot of car stuff. But stuff like this/ electrical isn't my cliche. Pics could be helpful if you didn't mind.I never had an aod. I can't imagine they have a clutch cut off switch though. I'd imagine that since the VSS runs off of the speedo cable, that's probably the same, though. I can show you pictures of my stuff from a T5 if that's relevant. Hopefully somebody's smarter than me can answer specifically the differences.
The only change that has to be made when going from AOD to 5-spd is the cruise cancel switch on the right hand side of the pedal box. When you swap to the 5-spd pedals, make sure this switch is attached otherwise it’s a PItA to do after the fact.
Photo of that switch here on right side
On the AOD cars you’ll find the plug clipped to the vertical support brace under the dash. Red wire with green stripe. There is a jumper in place.
Remove jumper, connect to above clutch switch.
Done.
That’s the only change. All the other circuits remain the same. Cruise is not incorporated into the two plugs (NGS, starter circuit) on the left hand side of the pedal box. You’ll need to connect those to the clutch switch anyway as part of the 5-spd swap regardless
Thank you for the info. It is greatly appreciated. Do you know the name of that part or a part number. All i can find for a clut h switch is this.. Def not the part in your pic.The only change that has to be made when going from AOD to 5-spd is the cruise cancel switch on the right hand side of the pedal box. When you swap to the 5-spd pedals, make sure this switch is attached otherwise it’s a PItA to do after the fact.
Done.
You are the man!!! You've been a great help to me! ! Hell all of you have!! Can I get your name? Thank you all!!!Switch Assy, Speed Control Release, Incl Wiring And Bracket, W/ Id Codes *E1db-9f645-Ac*, *E9zb-9f645-Ba*, Prior Part Number E1dz-9a837-A, F4zz-9a837-A - #M-9A837-3 - National Parts Depot
Buy part #M-9A837-3 Switch Assy, Speed Control Release, Incl Wiring And Bracket, W/ Id Codes *E1db-9f645-Ac*, *E9zb-9f645-Ba*, Prior Part Number E1dz-9a837-A, F4zz-9a837-A for your classic vehicle from National Parts Depot. Free shipping on orders over $300, fast delivery & everyday low pricing...www.npdlink.com
Thanks!!Right, if an AOD the harness gets a plug where the clutch switch would be
So the T5 needs the clutch dump switch
There is a lot to diagnosis for the speed control
Here are some diagrams from a1990 truck EVTM
The locations will be wrong, but the schematic will be basically the same
Do you have any pics of this switch installed on right side of pedal box? What does it connect too? Brake pedal? Is this the switch that cuts cruise off when brake is pressed? Sorry for all the questions but I just don't know anything about this. I'm guessing it's gonna be a PItA cause pedal assembly is already in car when bought...Thank you for the info. It is greatly appreciated. Do you know the name of that part or a part number. All i can find for a clut h switch is this.. Def not the part in your pic.
