- Mar 15, 2012
- 8
- 0
- 1
2006 GT 5speed. I'm having a problem that figure put at all. Short version of the symptoms. Random cylinders misfire at idle and low to mid-ish rpm's under load, and it lopes. Burnt matches/sulphur smell from exhaust. I have checked all the plugs and coils. Checked the MAF. Changed the TPS. Changed the fuel filter. Checked all 8 injectors and they are functioning. Run injector cleaner through it (do that regularly anyways). The battery and alternator are both ok, I changed both and no difference. Air filter (KNN cold air) is fine as is the throttle body and TB motor. I feel like I'm missing something else ive checked but idk long day. Have a pressure tester so I'll check for a blockage in the exhaust tomorrow. Don't know how to check the Evap system. I only have two ideas at this point what it could be and I don't even want to think about it(2 catalytic converters $$$$). Anyone else have ideas/suggestions/help? Thanks a lot guys.
