So much going on in here... Mike, the shifter turned out awesome. Very unique and fitting in the interior. As for the lights, take your time to sort it out. Don’t let them be an eye sore that bugs you until you replace them again.
Yeah I decided to ditch that plan.You figure out what you are doing with the laptop in the car?
It makes sense to me that I at least put a backer on those braces. Coming to terms with that means I'll have to remove more of that frame so that I can get a back glued and screwed on it though.Time to build a day care for the little Japanese kid and all his friends. And by that-I mean build a sub wall and use all that new found trunk space as the cabinet
I use the same struts to lift the trunk lid that everybody uses for their hoods ( albeit with much less lift pressure) Those torsion rods left the day I first laid a sawzall on the inner wheel tubs when I mini tubbed this thing.Is it maybe the bracing on the trunk lid? Or boot for our down under friend.
does your trunk lid (boot) have those long rods for springs to hold the lid up? They may be rattling. Annoying little buggers.
