Do your hazard flashers work properly? If they do then your problem is most likely a bad turn signal flasher. The flasher is located right underneath the dash inside the fuse panel. You can't miss the big round thing, it just unplugs. Now, if your hazrds do the same thing as your turn signals, then you'd probably have a wiring issue. Check the flasher first. Any parts store will have them and they're about 4 bucks or so.
