I just completed my 1965 Stang to EFI swap. Everything went well except one thing. IT WILL NOT START WITH THE TIMING SPOUT CONNECTED.
When I pulled out the timing spout works and idle great and is set to base timing 10 BTDC.
Everything seems to be working, I even bought a code scanner all I have in scanner is "111" system pass on KOEO.
I have double check all wiring connection, continuity, and grounds.
Any inputs is appreciated.
