my harmonic balancer is going out or is out...regardless...its bad...i crawled under the car today and looked at it...looked just like the pic posted in another thread on a harmonic balancer...also...its leaking oil out of that spot...its not dripping though...but there is alot of oil in that area that i dont think should be there...also...my throttle position sensor is going out...had a diagnostic ran today and came up with these numbers...124...181...189...556...
124 - throttle position sensor voltage higher than expected
181 - fuel system at rich adaptive limit at part throttle, system lean (bank #1)
189 - fuel system at rich adaptive limit at part throttle, system lean (bank #2)
556 - fuel pump relay primary circuit failure
i orderd a throttle position sensor with the part number F2SF-CA
but...there also was a F1SF-AA...
i dont know the difference but the picture in the computer was upside down on the later...and my part is the opposite way on my vehicle...like the pic of the first part number...both parts looked the same except they were flipped...and i couldnt see a part number anywhere on it...i think i got the right one...
and tonight on my way home, my battery light started flashing and flickering...my battery looks brand new...but...i have only had the car about 3 weeks...
last but not least...when i idle...in neutral or with the clutch in...sometimes coasting in 5th gear with no throttle...my oil pressure drops...and as soon as i tap the throttle, it comes back up...then drops again...the only time it doesnt do it is right after i initially start it up after its been sitting...
any help would be greatly appreciated...
