check this out....
14647
Vapor Management Valve Noise
may exhibit a high frequency air leak/rushing sound from the underhood/dash area. This may be caused by the vapor management valve mechanically grounding to an unseated stud mounting clip. To service, remove the vapor management valve. Reseat the stud mounting clips to the front right inner fender apron, and remount the vapor management valve without unseating the stud clips.
this may be it?
Just to make sure we have the same noise.... light sucking or whistle noise coming the from right side of interior starting at about 1900-2100 rpms, basically it comes and goes, more often when it is cold outside, under light throttle usually abruptly stops after rpm's go up to say 3000 maybe even sooner And a you can anticipate it because you can actually hear a very faint sucking noise stopped at idle.
