A couple of things come to mind:
Those catalytic converter images above look small. Very small. It's hard to imagine an exhaust system that you've calculated is right around the size it needs to be for the power we want to produce then putting a perforated plug into the mix. It seems to me that surface area of the catalyst need to be quite a bit larger in order to accommodate the same mass of air as the rest of the exhaust. In the words: It should be much larger.
The other thing that comes to mind about cats before turbos is the time that it spends cold and filling up those little holes with muck before it perfectly hot.
If I had nothing but time and money, I'd try installing two of those little cats in parallel on each side and see if it blew them out over time --or-- plumb a 4-inch cat inline with a 3-inch exhaust and see if that helped.
