I will check this out tonight but this could be the issue because not all carbs can just attach the cable to the existing kickdown lever. I know that Lokar sells a bracket that keeps the geometry correct between the two so that you can go full throttle without bottoming out. My cable is set where there is barely any tension on the cable at idle.
