There should be a phillips head screw at the top of that piece and on the bottom toward the back at the bottom, also two bolts at the bottom behind tow round plugs that need to be removed.
Fox Body Mustang Door Panel Removal Video - LMR.com
Need to remove the door panel in your Fox Body Mustang? Watch our removal video here!lmr.com
Check those bolts and screws,looks to have loosened up on you,or stripped out.
Thanks, but I’m asking, is there any fix for it, or is the panel just sunken in and in need of replacing?
This was the fix ^^^^ The video was to familiarize you with the location of the screws holding the door handle on. When you remove the handle you can also check if the door panel has torn where the metal clips slide under it from the handle.
Chris
Chris
I put them on my 90 GT. Here is before and after.
Do not forget to upgrade the power lock solenoids, and to clean and lube the latch mechanism. If you are in there to do it right, might as well finish it. I have replacement map pockets for next time, and plan on installing a second piece of elastic with the new ones.Of course, in true tinkering fashion, If I'm going to do anything to the doors, I might as well put some map pocket deletes on the panels, new bezels, armrests, and replace the speakers, right?
Thanks.There should be "push nuts" ( thats what I call them) there.. Remove your door panel and replace them... Should push off push new ones on..
Ahhhh, okay, thank you! I planned on overhauling the doors anyway.Push nuts have nothing to do with your crooked screw, you'll need to pull the entire door panel off to get that out. Those big screws thread into the metal door structure itself and clamp the door panel tight against the inside of the door, someone missed the hole and just left it, probably isn't screwed into anything hence your handle separating.
