I'm betting those bulbs wouldn't last a month before they blow. As for the housing it almost looks good. The little ball in the middle would look a little strange I think. Tribars look the best but they are expensive. Personally Halogen sealed beams are as good as it gets on a limited budget.
ok cause i was looking at atless making lights a little bit more brighter to see more. thanks for ur opinion cause personally i am not getting the things they dont look reliable. but what others are out there do you know.
I work at a speed shop, those (and many like them) are cheapo plastic lense lights. They generally leak, don't last very long and don't light up the road very good.
They have glass lenses. They are 100% brighter then the sealed beams. They come with cheapo generic bulbs, I put Piaa head light bulbs in them which make them even brighter. If you want funky looking ones Autoloc headlights look good and have a Decent price tag. (glass lenses).
Just some random link I pulled off the net, but yes the price is for each and 9003 is a fancy name for H4. The Hella's are worth every penny and they look cool too!
The H4 is held in with a wire retainer (Like a new car with H4'S) An H4 has 3 prongs on it like the sealed beam it replaces. The new light housing goes in the same way the sealed beam does. (headlight trim ring). No modifications needed, it simply replaces the sealed beam and plugs into the factory harness. You might want to add a relay. Check the voltage at the headlight plug, it is not unusual to find 10-11 volts there on an old car. By adding a relay you will get full batttery voltage to the headlight (making them even brighter).
