Recommend getting the PCM and cluster from the donor. The PCM and PATS module are programmed for each other.
Optionally, PATS can be disabled with a tuner.
When doing any swap, best to stick with the same transmission type (manual=manual, automatic=automatic). Otherwise expect re-flash of the PCM or drivability issues.
