87'GTstang
- Feb 16, 2004
- 1,025
- 0
- 0
Cool deal, missed the TW heads. I seriously doubt though you are going to find longer wires for your o2 sensors. Companies are not going to make a special emisions component in case someone wants to run a very non-stock item (in this case - long tubes). It just isn't cost-effective for a company to do so, but if they do, then i'de be impressed - i'm sure some company out there has seen the issue and maybe addresed it by now, who knows. If your search still turns up with no luck however, those extension harnesses are made for a reason and is probably the best way out is that be the case.
Also, while i'm thinking about it, is your speedo calibrated and are you sure you're not running around slower than you really are (the common gear-swap overlook)?
