But look at the grach... he basically tops out and holds the HP from 3600 to 5000 RPM.
I vote fuel issue (pump, pressure, injectors, something)...
reddy351 said:Yup. Used to be you could take off the intake silencer, set the timing to 13 deg, put in some 3.73's and rule the street. Now a Camry comes with more hp than our early Stangs. Big time !
QUOTE]
I drove a 2002 TA with the t56, slp lid, and k&n last weekend. It was crazy. I had an 88 z28 that I modded bigtime and a 94z28 auto and neither even compared to the 2002. It was very nice.
Therian said:not to jack this thread or anything...
Grady, are you still running stock TB and MAF? I thought you upgraded a while ago?
Therian said:any plans to hit a dyno again? I'd be very interested to see what you added...
keep up the good work
that could very well be the root of your problems right there. you havent done it in 2 years and there is no telling when the previous owner did it if at all. the ford racing wires are fine, they just take a little work to trim them down to size (they come way too long). toss in a new fuel filter, plugs, wires, and a new cap and rotor and see how she runs after that. also, what is your timing set at? retarded timing could also be part of the issue.302Snake said:i haven't done a tune up since having the car the last 2 years, just change the oil guess i'll do the tune up, are the ford racing wires good?
