I am replacing my clutch because I fried the TO bearing. I have a T-56 and I am installing a King Cobra clutch. I mounted the clutch to the flywheel (using the alignment tool), then the bellhousing. I am trying to get the transmission onto the bellhousing and I can't get it to mate up to the bellhousing. I can get in pushed in most of the way, but it just WON'T go the last 1/2".
On the T-56 there are two small dowel pins that line up the trans to the bellhousing. It looks like when one dowel is lined up, the other one is not lined up. Could the disc have moved? Or maybe it wasn't lined up accurately enough? It almost seems like it will not go into the pilot bearing. I'm at a loss. Something seems out of whack.
Thanks!!
Thanks!!
