- Feb 18, 2014
- 5
- 1
- 14
I know I'm getting spark. I know I'm not 180 degrees off on the distributor. When I pull the spark plugs they're all dry, no fuel on them. When I have the key in the on position and hand turn the motor I can hear the injectors pulse (if that makes sense), I've sprayed starting fuel and propane directly in the throttle body and it still doesn't try and start. I pulled the upper and sprayed starting fuel in two cylinders, I soaked them, still nothing. It'll turn over but will not try and start. What the hell is going on? 90 5.0.
This all started when I put on a tubular GT 40 upper and lower, used 70mm throttle body, new throttle body spacer, new throttle position sensor, used low mileage 38lb injectors with used MAF (doesn't try and start when I threw stock MAF on), and new cold air intake.
