overheating
2003 Mustang Workshop Manual
DIAGNOSIS AND TESTING Procedure revision date: 11/12/2002
Engine Cooling Printable View (58 KB)
Special Tool(s) Pressure Tester
014-R1072 or equivalent
73III Automotive Meter
105-R0057 or equivalent
Worldwide Diagnostic System (WDS)
418-F224,
New Generation STAR (NGS) Tester
418-F052, or equivalent scan tool
Battery/Anti-Freeze Tester
014-R1060 or equivalent
Inspection and Verification
WARNING: Never remove the pressure relief cap while the engine is operating or when the cooling system is hot. Failure to follow these instructions can result in damage to the cooling system or engine or personal injury. To avoid having scalding hot coolant or steam blow out of the degas bottle when removing the pressure relief cap, wait until the engine is cooled, then wrap a thick cloth around the pressure relief cap and turn it slowly. Step back while the pressure is released from the cooling system. When you are sure all the pressure has been released, turn and remove the pressure relief cap (still with a cloth).
CAUTION: Check the coolant level, engine oil and transmission fluid, top off the coolant if needed. If there is engine coolant in the engine oil or transmission fluid, the cause must be corrected and oil/fluid changed or major component damage may occur.
Verify the customer's concern by operating the engine to duplicate the condition.
Inspect to determine if any of the following mechanical or electrical concerns apply.
Visual Inspection Chart Mechanical
Leaks
Hoses
Hose clamps
Water gasket
Head gaskets
Intake manifold gasket
Coolant pump
Radiator
Degas bottle/coolant expansion tank
Heater core
Fan/fan clutch
Engine coolant temperature sensor (4.6L)
Cylinder head temperature sensor (3.8L)
Circuitry
If the inspection reveals an obvious concern that can be readily identified, repair as necessary.
CAUTION: Some vehicle cooling systems are filled with Motorcraft Premium Gold Engine Coolant VC-7-A (in Oregon VC-7-B) or equivalent meeting Ford specification WSS-M97B51-A1 (yellow color). Always fill the cooling system with the same coolant that is present in the system. Do not mix coolant types.
NOTE: The addition of Motorcraft Cooling System Stop Leak Pellets, VC-6, darkens Motorcraft Premium Gold Engine Coolant from yellow to golden tan.
Inspect the coolant condition.
Inspect the coolant color.
If Motorcraft Premium Gold Engine Coolant (yellow color) VC-7-A (in Oregon VC-7-B) or equivalent meeting Ford specification WSS-M97B51-A1 has a clear or pale yellow color, this indicates higher water content than required.
Dark brown can indicate unauthorized stop leak may have been used. Use Motorcraft Cooling System Stop Leak Pellets VC-6 or equivalent meeting Ford specification ESE-M99B37-5 except as noted in ES-F6SE-19A511-AA only.
A light or reddish brown color indicates that rust may be present in the cooling system. Flush the system and refill with the correct mixture of water and engine coolant.
An iridescent sheen on top of the coolant can indicate a trace of oil is entering the system. For additional information on engine diagnosis, refer to Section 303-00 .
A milky brown color may indicate that either engine oil or transmission fluid is entering the cooling system. If transmission fluid is suspected, the cause may be a leaky radiator. Pressure test the cooling system. For additional information, refer to component tests in this section. If engine oil is suspected the cause of the leak may be internal to the engine. For additional information, refer to Section 303-00 .
If the engine coolant appearance is acceptable, test the engine coolant freezing point range with the battery and anti-freeze tester. The freezing point should be in the range -40°C to -20°C (-50°F to -10°F). If the vehicle is driven in cold climates less than -32°C (-34°F), it may be necessary to increase the coolant concentration to get adequate freeze protection.
Maximum coolant concentration is 60% coolant/40% water.
Minimum coolant concentration is 40% coolant/60% water.
Adjust coolant range and level, if necessary:
If coolant is low, add specified coolant mixture only.
If the engine coolant tests too weak, add straight engine coolant until the readings are within acceptable levels.
If the engine coolant tests strong, remove some of the engine coolant and add water until the readings are within acceptable levels.
If the concern remains after the inspection, determine the symptom(s) and GO to Symptom Chart
Symptom Chart
Symptom Chart Condition Possible Sources Action
Loss of coolant
Radiator.
Coolant pump seal.
Radiator hoses.
Heater hoses.
Heater core.
Engine gaskets.
Degas bottle or coolant expansion tank.
Go To Pinpoint Test A .
The engine overheats
Thermostat.
Coolant pump.
Internal engine coolant leak.
Radiator.
Cooling fan.
Pressure relief cap or radiator cap.
Go To Pinpoint Test B .
The engine does not reach normal operating temperature
Thermostat.
Go To Pinpoint Test C .
Pinpoint Tests
PINPOINT TEST A: LOSS OF COOLANT
Test Step Result / Action to Take
A1 CHECK THE ENGINE COOLANT LEVEL
WARNING: Never remove the pressure relief cap while the engine is operating or when the cooling system is hot. Failure to follow these instructions can result in damage to the cooling system or engine or personal injury. To avoid having scalding hot coolant or steam blow out of the degas bottle when removing the pressure relief cap, wait until the engine is cooled, then wrap a thick cloth around the pressure relief cap and turn it slowly. Step back while the pressure is released from the cooling system. When you are sure all the pressure has been released, turn and remove the pressure relief cap (still with a cloth). NOTE: Allow the engine to cool before checking the engine coolant level.
Key in OFF position.
Visually check the engine coolant level at the degas bottle or coolant expansion tank.
Is the engine coolant level within specification?
Yes
GO to A2 .
No
REFILL the engine coolant as necessary. GO to A2 .
A2 CHECK THE PRESSURE RELIEF CAP
Carry out the Cap—3.8L or Cap—4.6L test. Go to Component Tests in this section.
Is pressure relief cap/radiator cap OK?
Yes
GO to A3 .
No
INSTALL a new pressure relief cap/radiator cap. TEST the system for normal operation.
A3 CHECK THE ENGINE COOLANT FOR INTERNAL LEAK
Inspect the engine coolant in degas bottle/coolant expansion tank for signs of transmission fluid or engine oil.
Is oil or transmission fluid evident in the coolant?
Yes
If engine oil is evident, REFER to Section 303-00 . If transmission fluid is evident, REPAIR or INSTALL a new radiator as necessary.
No
GO to A4 .
A4 CHECK THE ENGINE AND THE TRANSMISSION FOR COOLANT
Remove the oil level dipstick from the engine and the transmission.
Is coolant evident in the oil or transmission fluid?
Yes
If coolant is in engine, REFER to Section 303-00 . If coolant is in transmission, REPAIR or INSTALL a new radiator as necessary. To repair the automatic transmission, REFER to Section 307-01 .
No
GO to A5 .
A5 PRESSURE TEST THE ENGINE COOLING SYSTEM
Pressure test the engine cooling system. Go to Component Tests in this section.
Does the engine cooling system leak?
Yes
REPAIR or install new components. TEST the system for normal operation.
No
The cooling system is operational. GO to Symptom Chart .
PINPOINT TEST B: THE ENGINE OVERHEATS
B1 CHECK THE ENGINE COOLANT LEVEL
WARNING: Never remove the pressure relief cap while the engine is operating or when the cooling system is hot. Failure to follow these instructions can result in damage to the cooling system or engine or personal injury. To avoid having scalding hot coolant or steam blow out of the degas bottle when removing the pressure relief cap, wait until the engine is cooled, then wrap a thick cloth around the pressure relief cap and turn it slowly. Step back while the pressure is released from the cooling system. When you are sure all the pressure has been released, turn and remove the pressure relief cap (still with a cloth). NOTE: If the engine is hot, allow the engine to cool before proceeding.
Check the engine coolant level at the degas bottle/coolant expansion tank.
Is the engine coolant OK?
Yes
GO to B2 .
No
REFILL the engine coolant at the degas bottle/coolant expansion tank. Go To Pinpoint Test A .
B2 CHECK THE COOLANT CONDITION
Check the coolant for dirt, rust or contamination.
Is the coolant condition OK?
Yes
GO to B3 .
No
FLUSH the engine cooling system. REFER to Engine and Radiator Flushing in this section. TEST the system for normal operation.
B3 CHECK FOR AN AIRFLOW OBSTRUCTION
Inspect the A/C condenser core and radiator for obstructions such as leaves or dirt.
Is there an obstruction?
Yes
REMOVE the obstruction. CLEAN the A/C condenser core and radiator. TEST the system for normal operation.
No
GO to B4 .
B4 CHECK THE WATER THERMOSTAT OPERATION
Start the engine and allow the engine to run for ten minutes.
Feel the inlet and outlet heater water hoses and the underside of the upper radiator hose.
Are the upper radiator hose and the heater water hoses cold?
Yes
INSTALL a new water thermostat. REFER to Thermostat — 3.8L , Thermostat — 4.6L(2V) or Thermostat — 4.6L(4V) in this section. TEST the system for normal operation.
No
GO to B5 .
B5 CHECK THE COOLING FAN OPERATION
Carry out the cooling fan component tests. Go to Component Tests.
Is the cooling fan operation OK?
Yes
For diagnosis and testing of the engine, REFER to Section 303-00 .
No
INSTALL a new fan component as necessary. TEST the system for normal operation.
PINPOINT TEST C: THE ENGINE DOES NOT REACH NORMAL OPERATING TEMPERATURE
C1 CHECK THE ENGINE TEMPERATURE
Start the engine and allow the engine to idle for ten minutes.
Feel the inlet and heater water hoses and the underside of the upper radiator hose.
Yes
No
For diagnosis and testing of the engine coolant temperature gauge, REFER to Section 413-01 .
Component Tests
Pressure Test — 3.8L
Remove the radiator cap. Fill the radiator as needed. Fit the pressure tester to the radiator neck, using an aftermarket adapter.
CAUTION: Do not pressurize the cooling system beyond 110 kPa (16 psi).
Pump the cooling system to a maximum of 102 kPa (14.9 psi) and hold for 2 minutes. If the pressure drops within this time, inspect for leaks and repair as necessary.
Pressure Test — 4.6L
Turn the engine OFF.
Check the engine coolant level; refer to Cooling System Draining, Filling and Bleeding in this section.
Connect Radiator Heater Core Pressure Tester to the degas bottle nipple and vent hose. Install a pressure test pump to the quick-connect fitting of the test adapter.
CAUTION: Do not pressurize the cooling system beyond 152 kPa (22 psi).
NOTE: If the plunger of the pump is depressed too quickly, an erroneous pressure reading will result.
Slowly depress the plunger of the pressure test pump until the pressure gauge reading stops increasing and note the highest pressure reading obtained.
If the pressure relief cap does not hold pressure, remove and wash the pressure relief cap in clean water to dislodge all foreign particles from the gaskets. Check the sealing surface in the filler neck.
If 110 kPa (16 psi) cannot be reached, install a new pressure relief cap. If more than 124 kPa (18 psi) shows on gauge, install a new pressure relief cap.
CAUTION: If the pressure drops, check for leaks at the engine-to-heater core hoses, engine-to-radiator hoses, water valve hose (if applicable), oil cooler return tube gasket (6N789), radiator and heater core or other system components and connections. Any leaks which are found must be corrected and the system rechecked.
Pressurize the engine cooling system as described in Step 4 (using a pressure relief cap that operates within the specified upper and lower pressure limits). Observe the gauge reading for approximately two minutes; refer to General Specifications. Pressure should not drop during this time.
Release the system pressure by loosening the pressure relief cap. Check the engine coolant level and replenish, if necessary, with the correct engine coolant mixture; refer to Cooling System Draining, Filling and Bleeding in this section.
Cap — 3.8L
Inspect the radiator cap and seals for damage or deterioration. Install a new radiator cap if necessary.
Fit the radiator cap to Radiator/Heater Core Pressure Tester Kit, using the aftermarket adapter.
NOTE: If the plunger of the pressure tester is depressed too fast, an incorrect pressure reading will result.
Slowly pump the pressure tester until the pressure gauge stops increasing and note the highest pressure reading. Release pressure and repeat the test. Install a new radiator cap if the pressure is not 99.3-121.4 kPa (14.4-17.6 psi).
Cap — 4.6L
Remove the pressure relief cap from the degas bottle.
Follow the instructions from the pressure tester.
If the pressure test gauge readings are not within specifications, install a new pressure relief cap. If the pressure test gauge readings are within specifications, carry out the cooling system Pressure Test.
Thermostat — Water
A new water thermostat should be installed only after the following electrical and mechanical tests have been carried out.
Thermostat — Electrical Test
CAUTION: Always vent the exhaust to the outside when carrying out this test.
NOTE: The electrical thermostat test is most accurate if carried out at less than 37.8°C (100°F) ambient air. This test may be carried out with or without the hood open and with the engine warm or cold.
Check the engine coolant level. Fill as needed.
With the ignition OFF, remove the engine coolant temperature (ECT) (4.6L) or cylinder head temperature (CHT) (3.8L) sensor harness connector and attach ECT (4.6L) or CHT (3.8L) Sensor "T" Cable as a jumper between the powertrain control module (PCM) (12A650) and the ECT (4.6L) or CHT (3.8L) sensor. Attach the 73III Automotive Meter to the ECT (4.6L) or CHT (3.8L) Sensor "T" Cable. Voltage values (0-5 V) may now be monitored while the sensor retains its connection to the wiring harness.
An appropriate diagnostic tool may be used to monitor the ECT on vehicles equipped with data link connector (DLC).
NOTE: Running this test with the vehicle in gear or with the A/C compressor clutch engaged (running) will cause incorrect diagnosis.
Place the transmission in PARK (P) or NEUTRAL (N).
Start the engine and allow the engine to idle throughout this test. Allow the engine to run for 2 minutes, then record the ECT (4.6L) or CHT (3.8L) voltage. Record the ECT (4.6L) or CHT (3.8L) voltage every 60 seconds. When the ECT (4.6L) or CHT (3.8L) voltage trend changes direction or only changes slightly (0.03 volts or less) from the previous reading, record this as the thermostat opening voltage. Use the voltage and corresponding coolant temperature chart listed below for 4.6L engines only.
Coolant Temperature °C (°F) ECT (Volts)
22 (71) 3.00
43 (109) 2.01
71 (159) 1.01
82 (180) 0.75
91 (195) 0.059
97 (206) 0.050
105 (221) 0.040
If the thermostat opening voltage is greater than 0.75 volts and less than 82°C (180°F), install a new water thermostat.
If the thermostat opening voltage is less than 0.75 volts and greater than 82°C (180°F), the water thermostat is good and a new water thermostat should not be installed. GO to Symptom Chart for further instructions.
Thermostat — Mechanical Test
Remove the water thermostat.
Check the water thermostat for seating. Hold the water thermostat up to a lighted background. Leakage of light around the thermostat valve at room temperature indicates that a new water thermostat should be installed. Some water thermostats have a small leakage notch at one location on the perimeter of the thermostat valve, which is considered normal.
Immerse the water thermostat in a boiling coolant and water mixture.
See the General Specifications chart for water thermostat opening temperatures.
Radiator Leak Test, Removed From the Vehicle
CAUTION: Never leak test an aluminum radiator in the same water that copper/brass radiators are tested in. Flux and caustic cleaners may be present in the cleaning tank and they will damage aluminum radiators.
NOTE: Always install plugs in the oil cooler fittings before leak-testing or cleaning any radiator.
NOTE: Clean the radiator before leak-testing to avoid contamination of tank.
Leak-test the radiator in clean water with 138 kPa (20 psi) air pressure.
Fan — Electric Test
Refer to the Powertrain Control/Emissions Diagnosis (PC/ED) manual.
