When starting car after it has cooled down like over night it has a hard time staying started the first time unless I flick the gas. Then stutter while under hard acceleration until up to operating temp. Note the temp outside is avg 70F to 90F. Also at any time at WOT I need to play with the gas to prevent stuttering.
I this an injector problem? I have used injector cleaner, Lucas fuel additive and only use quality fuel like shell or Mobil.
Car Info:
1996 Mustang GT
32V Motor from '96 Cobra
Kenne Bell 1.7 S/C 5-6psi
Kenne Bell Boost-a-Pump
Kenne Bell PCM Chip
IMRC delete
Ford Racing 9mm Wires
Long tube headers
Cat H-Pipe
SLP Pipes w/glasspacks
Auto meter Fuel pressure gauge
Auto meter boost gauge
Auto meter coolant temp gauge
Auto meter oil pressure gauge
Wiring harness has been corrected for the 32v
Thanks in advance for any help!
Car Info:
1996 Mustang GT
Kenne Bell PCM Chip
IMRC delete
Long tube headers
Cat H-Pipe
