Understood.
Problem with rear main leaks is it will leak more while driving than just sitting in the garage not moving. So you may be leaking more oil than you think from the Rear Main seal. If the seal is not at fault, then its a crankcase pressure problem. To much pressure will force oil out in places it shouldnt be.
Do all your plugs look good? If your burning that much oil, it will show in the plugs.
