Hi.. do certain mods change how low the engine can idle... I can't seem to get it to idle less than about 700 800 rpm.. and when I adjusted the set screw and re adjusted the tps to get around .9 volts I still can only get it down to about 700.. actually had the throttle stick because I think I had the set screw too low.. with underdrive pulleys.. headers... is it possible for the car to not be able to idle lower.. and does timing affect how low the car can idle?? I get code 13 which says that the engine could not perform the lower rpm test.. any ideas???
