Intake heater hose fitting size
Thanks guys. Craig, When I took mine off aaaaaaaaaages ago (since binned hence asking the question) it seemed to be just a rightangled pipe with thread.
Do you know how big the restrictor is? If its not too big I might just run -8 instead of -10 line
11/16 for the elbow deal, but my performer rpm intake required a bushing as well.
Water in elbow, 64 - 73 289 Water In Elbow Silve Mustang
The bushing is probably 13/16 or 7/8, not sure, let me know how to measure and I'll confirm.
My question is, can I ditch the elbow? Don't wanna buy another, would rather just plumb directly to the intake.
FYI I currently have 2 temp sensors in my intake - 1 in the correct space and one in the heater hole. The other water pump line is just blocked off.
I have been running this setup for 2+ years with no problems at all.
You cannot just ditch the stock elbow. It has a restrictor inside of it and will nuke a heater core with a single pass over 3000 RPMs.
Somebody ask me how I know this.
What about the later model 5.0 metal tube setups? I've got one of these, just don't wanna chance the o-ring inside of it.
Anyway, they don't seem to have any sort of restriction.
THe restriction is the extended tube sticking down in the water stream. I found the thread from the 5.0 forum. Read past the 5.0 tech on the heater core down to the part about the flow restrictor. THere are pictures father down
Mustang
THis will allow you to use a regular AN elbow without bursting the heater core.
Note: this applies to a 5.0 heater core, the early heater core may be diferent. You would need to check the sizes/fitment etc. so you don't send an aluminum slug flying into the heater core!
No, it's not. That tube is a reverse standpipe, its function is to prevent air bubbles entering the heater.
See below for the restriction.
You have to look inside the hose nipple. The steel head that provides the 90° bend on OEM units is only drilled about 3/16" inside the bend, constricting much smaller than the 3/8 tube standpipe and the 5/8 hose connection. I can't say if repro connectors are made properly in this regard. The thermostat water neck with the bypass hose nipple also originally had a steel insert controlling it down to about 1/4". Replacement and repro units commonly have a larger ID, permitting too much coolant to bypass the radiator.
It would be a simple matter to insert a small steel tube to create this restriction.
