Is it ok to change Idle speed if car is dyno tuned and chipped???
juiced_94gt
1,143
Southern California
My car is already dynotuned and chipped with a diablosport chip...the tunner set the idle at 900RPM's but I would like to have it a little lower to hear the cam some more...what is a good idle speed? also can the TSP voltage be changed without affecting the tune???
  • Sponsors(?)
Stanger007
2,015
38
Baton Rouge, LA
www.72mach1.com
There are a few different ways of setting up the idle in a tune. I'd get ahold of your tuner and ask his opinion or just try it and remember how to get back to where you were after the change.
Pull the negative battery cable and hold the brake a few seconds to clear the ISC learning.
Wes
Thread starter Similar threads Forum Replies Date
J Changed plug wires now car idles fast 1965 - 1973 Classic Mustangs -General/Talk- 2
M 1981 high idle after 1 barrel carb change 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
KyleEBK Changing Base Idle 92 5.0 Engine Fox 5.0 Mustang Tech 5
billison Change In Idle After 3g Swap.. Fox 5.0 Mustang Tech 15
99 FLA PONY GT Engine WTF...changed IAC valve, Platinum spark plugs, fuel filter & PCV valve-still idling rough. SN95 4.6L Mustang Tech 6
J Help!! Changed Clutch, Now Stalls And Idles Up And Down SVT Tech Forum 5
P Stalling and rough idle after spark plug and wire change Fox 5.0 Mustang Tech 16
C I changed my iac and the engine is still massivly surging idle SN95 4.6L Mustang Tech 2
aar0s changed intake gaskets, now high idle Fox 5.0 Mustang Tech 12
0 Low idle rpm. Sometimes cuts out. Changed IAC. No difference...? SN95 4.6L Mustang Tech 7
erniet17 No Change in idle or timing with spout removed Fox 5.0 Mustang Tech 4
chaos254 high idle...unplugged IAC w/ no change 1994 - 1995 Specific Tech 7
jayrw 2000 GT, Heater causes random idle change. SN95 4.6L Mustang Tech 7
S When disconnecting IAC Motor, idle doesnt change Fox 5.0 Mustang Tech 6
AnthonyR23 Idle.. changes with mods? Fox 5.0 Mustang Tech 2
kingc Changed the idle with tune and now a concern SN95 4.6L Mustang Tech 4
J rough idle after plug change??? Fox 5.0 Mustang Tech 5
A Backfire on idle change SN95 4.6L Mustang Tech 1
zenboy99 High idle with timing change 1994 - 1995 Specific Tech 11
94opalgt idle problems again after change,please help 1994 - 1995 Specific Tech 12
spdfrkaby need help on rough idle. changed iac to no avail. SN95 4.6L Mustang Tech 7
J idle sticking after thermostat sender changed Fox 5.0 Mustang Tech 0
S Wierd idle after changing gears 1994 - 1995 Specific Tech 8
9 Changed Intake Gasket..Now Car Idles At 200 RPM? Fox 5.0 Mustang Tech 1
C RPM dropped below 500 rpm while idling after oil change?? SN95 4.6L Mustang Tech 10
Legendary Unplugged IAC and no change in Idle Fox 5.0 Mustang Tech 10
W Engine Oil Change Interval for a car that is not used much ? Fox 5.0 Mustang Tech 12
91GTstroked Engine Changing lower intake gaskets Fox 5.0 Mustang Tech 15
T changing wheels 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
F Changing 4inch stock center screen to 8inch double din 2015+ (S550) Mustang -General/Talk 0
LILCBRA Oil pan gasket change OR starter replacement in a 302 II 1974 - 1978 Mustang II Talk & Tech 11
J Sudden change in motor 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
M PCM change for tranny swap? '94 V6 1994 - 1995 Specific Tech 1
92j3ieje8 How many miles is an oil change needed for a v6 o4 mustang? 1996 - 2004 SN95 Mustang -General/Talk- 0
kiddiccarus Considering Changing Fuel Pump (Discussion With Myself) 1996 - 2004 SN95 Mustang -General/Talk- 3
R 2013 Mustang GT pad and rotor change, need help. 2005 - 2014 S-197 Mustang -General/Talk- 4
P Help..need on changing tranny dipstick. SN95 V6 Mustang Tech 0
C how to change the ignition on a mustang I just want to know I've been looking around and I can't find it for a specific year and Mom for a mustang II 1974 - 1978 Mustang II Talk & Tech 9
H 96 Gear Change Information 1996 - 2004 SN95 Mustang -General/Talk- 7
J 2014 humming noise from engine, changes pitch with turning of steering wheel 2010 - 2014 Specific Tech 1
D 93 LX 2.3L no change when I unplug MAF 2.3L (N/A & Turbo) Tech 12
from6to8 The bible on what to change while the motor is out? 1994 - 1995 Specific Tech 6
Mstng93SSP Has anyone used the tool to hold lifters up for cam change? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 28
darryl paarman Changed engine configuration - reload base map? Digital Self-tuning Forum 18
7 Engine 351W year to year changes? 1974 - 1978 Mustang II Talk & Tech 5
J How far can i go without changing the computer 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
1992 5.Slow GT Nitrous on a 98 explorer motor, yes/no if not what do i need to change? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
John Dirks Jr Cooling system changes 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
G Progress Thread change of look for sn95 1996 - 2004 SN95 Mustang -General/Talk- 1
O Changing transmission fluid in 94 V-6 SN95 V6 Mustang Tech 0
