MAF help! For 24lb injectors
88-90ConVerts
33
Ponte Vedra,Fl
I have a MAF meter from a sn95 the number is F2VF-12B579-A1A. My question is can this work with 24lb injections? I know it's calibrated for 19lb injectors.
  • Sponsors(?)
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
33,075
9,215
224
Massachusetts
Oem MAFs aren't calibrated. The "calibration" for an aftermarket MAF is to resize the sample tube to trick the ECU into seeing less air than it is, signaling the ECU to injection less fuel with the larger injectors.
If you want to use 24s with the oem MAF, you need a tune. If you don't want to do that, then you need to buy an aftermarket MAF and fool the ECU
  • Agree
Reactions: General karthief
88-90ConVerts
33
Ponte Vedra,Fl
Thanks Mustang5L5 that makes sense.
Thread starter Similar threads Forum Replies Date
8 Plz Help! ‘88 Mustang will not idle and runs poorly Fox 5.0 Mustang Tech 4
88foxbodyowner Engine MAF Conversion Help Fox 5.0 Mustang Tech 6
S Fox MAf help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
B Help maf vs tb 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
F MAF location? Please help Fox 5.0 Mustang Tech 16
A Need help identifying MAF sensor plug and MAF issue Fox 5.0 Mustang Tech 14
C Engine Maf Sensor Help Please! Fox 5.0 Mustang Tech 40
Z 95 5.0 Maf Not Working 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
C Car Cranks But Wont Start After Maf Sensor Cleaning - Please Help. 1996 - 2004 SN95 Mustang -General/Talk- 0
all1knew Help - What Blow Through Maf's Are Out There For Me ? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
Amber Midkiff Please Help 1996 - 2004 SN95 Mustang -General/Talk- 5
F Need Help Asap With Maf Sensor Fox 5.0 Mustang Tech 0
viper_dude_06 Maf Conversion Confusion, Please Help Fox 5.0 Mustang Tech 41
MFE92 Need 92 5.0 Maf Circuit Help Fox 5.0 Mustang Tech 10
G Need Quick Help With 92 Gt Maf Wiring Fox 5.0 Mustang Tech 3
Buko Code 66 Low Maf Voltage- All Checks Ok. Ecm? Help! Fox 5.0 Mustang Tech 4
Codydubb 73 Mm C&l Maf F1zf-12b579-aa Afh55-03b 8f06 Sensor Help!!?? Fox 5.0 Mustang Tech 5
N MAF conversion help Fox 5.0 Mustang Tech 16
0 HELP!! 94-95 MAF Conversion to FOX Fox 5.0 Mustang Tech 11
arbailey Need help finding MAF part Fox 5.0 Mustang Tech 6
jonbacon MAF help... Fox 5.0 Mustang Tech 1
flashback87 new maf help!!!!!! Fox 5.0 Mustang Tech 3
B maf computer help? Fox 5.0 Mustang Tech 2
jonbacon MAF help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 24
flashback87 MAF HELP PLEASE!!!! Fox 5.0 Mustang Tech 3
mustang863 twin turbo fox need help info on this maf Fox 5.0 Mustang Tech 1
F maf sensor help 1994 - 1995 Specific Tech 5
B Need help with MAF coversion Fox 5.0 Mustang Tech 7
E Maf housing problem, help please? SN95 4.6L Mustang Tech 2
E Maf housing problem, help plese? 1996 - 2004 SN95 Mustang -General/Talk- 0
E Maf housing problem, help please? 1996 - 2004 SN95 Mustang -General/Talk- 0
E Maf houshing problem?? any help please. SN95 V6 Mustang Tech 6
S I need help with MAF info. PLEASE! Fox 5.0 Mustang Tech 3
PR_wingman MAF conversion fuel pump issue NEED HELP Fox 5.0 Mustang Tech 4
P need help with maf selection!!! Fox 5.0 Mustang Tech 9
D Help with MAF Conversion Fox 5.0 Mustang Tech 1
UPRMike Help me help a customer. What MAF CAI is this? 2005 - 2009 Specific Tech 6
TeKKiE Help wanted: 90MM Lightning MAF Voltages Other Auto Tech 1
F MAF Conversion Help Fox 5.0 Mustang Tech 11
timeless2 StangNet help requested for stock MAF on 2001 GT 1996 - 2004 SN95 Mustang -General/Talk- 13
B HELP NEW HERE 5.0 MAF Fox 5.0 Mustang Tech 5
Manewaymja2 SD to MAF Conversion. Have Harness Need Help. Fox 5.0 Mustang Tech 3
Kdubslugga MAF code 26 problem need help! Fox 5.0 Mustang Tech 13
B I NEED HELP PLEASE!! MAF!! 1994 - 1995 Specific Tech 3
F Mystery MAF, can you help identify? Fox 5.0 Mustang Tech 7
'88Cobra MAF Sensor Question, Need Help! Fox 5.0 Mustang Tech 5
8 86gt maf conversion wiring issues 2 years still no go after mods please help my 5.0 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
Blue91GT 70MM Cobra MAF Help.... Fox 5.0 Mustang Tech 11
M map to maf swap help Fox 5.0 Mustang Tech 6
W Need help with MAF and air tube/filter for EFI swap in a '65 Fox 5.0 Mustang Tech 6
