I found that my passenger window switch is not operating. Makes the clicking sound on both up and down, but no window movement. Lock/unlock switch operates fine and window goes up/down with no problems when using the driver side switch. I had this happen once before, but when i took the door panel off, the switch started working again with no problems. No such luck this time. All the connections going to the switch appear to be fine.
This sound like a problem with the switch? wiring?
Is there any voltage test I can check on the switch?
