I first got TPS error.Replaced it and now getting pps error.No acceleration,I don't know where it is and certainly have no idea how to fix it.Please help
My Ford reference says that a P0211 is an injector circuit failure to cylinder #11. Have you done a 12 cylinder conversion that you failed to mention?
Could it be P0121 TPS circuit performance problem? This is NOT a pedal position error. Do you see why it's important to post the DTC codes?
If so, the #1 thing to check is binding throttle linkage. Are the throttle return springs in place? There should be two. Does the throttle work smoothly opening/closing?
Since the DTC calls out the TPS and the TPS sensor itself is new, this most likely means a wiring problem. Look for bent, pushed pins. Are the pins clean? Any damage to the wiring harness?
>> P0121 - Throttle Position (TP) Circuit Performance Problem
