Guys,
I am stumped at the fact that my car tends to overheat (temp keeps rising) while going 70 on the freeway (Under Load). My car is stock factory with the exception of an Aluminum Rad. My cooling system (Water Pump / Heater Core Bypass/ 180 Degree Therm. / New Upper & Lower Hoses / Stock Plastic Fan w/Working Clutch) has been checked and rechecked. I have also run the car on the freeway without the Thermostat and still overheats (probably not allowing the coolant to cool in the Rad?). I am leaning towards being a clogged Radiator or something clogged in the block, however when I turn the car on and look into the Radiator via where the cap goes, I can see coolant flowing slowly almost dripping thru the core tubes. Also, I do not lose any coolant or get a smell of coolant in the interior or underneath the car.
For example, with a 15 mile stretch (15-20 minutes) of freeway (free flowing) the car (somewhat cool) went from 160 degrees to 260, all this happening while I was going about 70 mph. My temperature is based on an electronic AutoMeter H20 guage I installed in the OEM hole for the stock gauge (Drivers side front on the intake).
Any help or suggestions would be appreciated. Since I have bypassed the heater core (before overheating started), can I still flush the cooling system?
The Radiator is about 6 years old.Sorry,
I also installed a 1993 Cobra Water Pump Pulley (smaller dia.). I do not have underdrive pulleys.
Thanks in advance for any advise.
