heyy..about to slap in my e-303 cam and timing chain...
what i know from so far is you have to lube up the cam with prelube..which i have...then...my cams getting advanced 4*...so u line up the dot on the top gear with the 4* mark on the bottom gear correct...while the cranks on tdc..which would just be the keyway facing up and the number piston all the way at the top correct...my engines on a stand by the way..everything is new...
is that all u have to know..is have the number one piston at the very top..and bolt eveythin up..and then u can turn the crank and everything will be set and stay there right....please add to this...thanks guys...
just walk me through it so its everything is ready for the next step..which woudl be putting on the damper and everythign else that slides on the crank..right...?
any tips on that
any tips on that
