K guys...well I got around to taking my upper and lower intake off to replace the gaskets that I'm pretty sure are causing my leak...I blame this on not changing out my pcv valve.......I could be wrong though.
So my question is..I have a spacer to go between my upper and lower intake and I was wondering if I should lay a thin line of RTV around the gaskets before sealing them.
And on to the lower intake to block/heads gasket....I just place RTV on the four corners correct?
Thanks for any input,
Clay :SNSign:
Oh yes, one more question. When I was pulling my upper intake bolts I noticed that one of my rear ones had a good amount of corrosion and junk on it....any ideas where that could be from? It was pretty much the entire length of the bolt
Thanks again and sorry about the length
Clay :SNSign:
