rear brake hoses
89drop
175
is there a set of brake hoses that will bolt up to the fox body hard lines when changing over to the sn95 rear disc? this is the last step to my 5 lug/brake conversion and i just cant seem to find it and i left the brake hoses behind because one was cut. thanks guys!
You can get the stock SN 95 hoses from an autoparts store and use them with Maximum Motorsports adapters. Brake Line Adapter Kit, Rear disc Conversion, 1979-93 Mustang [MMBAK-18] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader!
You can also get the stainless hoses from Maximum Motorsports too. It's just a little pricey but if you're going to upgrade the brakes then do it right the first time.
i knew about the adapters, Mike helped me out with those. thanks though! i was just hoping to get a hose that was a direct bolt on like MM makes for the front...
