- Mar 22, 2017
- 27
- 0
- 1
So my first time rebuiling my 99 gt had it torn down to the block and tranny in and that's it. I did as much research and video watching and started the rebuild. I installed heads and with new gaskets, then did the timing side with new chains, guides, etc (oiled them), did timing cover and pulleys, installed new typhoon intake kit, shorty headers and x pipe, poured oil over the timing chains, cams, and stuff before putting vavle covers back on. Then I filled fluids and hooked battery up. I left injectors unplugged and primed fuel pump after connecting shut off switch by turning key to ON/engine off. Then I turned over and held key over for 10 second to turn the enine without starting to cycle fluids (twice). Then I finally connected injectors amd started car. Started right up and idled perfect. Sounded perfect....... But then it started smoking from what looks like between the bottom valve covers and header areas. We thought it was just burning off oil drippige but got more Smokey then all the sudden it started idling rough and making a light knocking sound. Turned it off and tried to look over. I'm lost. Any ideas. Seems like there may not be oil getting to the cam areas maybe making the cams dry (I don't know) HELP ME
