Engine too much Oil pressure possible ??
marcelo
160
29
38
59
Quepos, Costa Rica, Central America
got my new 331cu together and in the engine is running very nice ....installed a Melling High pressure oil pump with ARP shaft ...oil pressure goes up to 80psi when cold and drops to 60 when hot ..at idle...with 10/30 mineral oil... can there be too much oil pressure ?? what Oil pressure are you running .. with aftermarket oil pump..?
  • Sponsors(?)
TOOLOW91
7,147
234
S.I.NY
Can be to much If the bearings are not clearanced for it . It tries to cram oil into a space it can’t get into and the pressure goes sky high .
Also what pan is on it ?
They are known to suck a stock pan dry . ( apparently internet myth ) see below .
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
27,401
2,846
234
74
Dublin GA
lowendmac.com
Also what pan is on it ? They are known to suck a stock pan dry .
Wrong answer...
Thanks to Stangnet member bubba-dough for helping to educate all of us by finding this article... :nice:
http://www.mellingengine.com/Portals/5/pdf/pdf_catalog/high-volume-pumps.pdf You will need the Adobe Acrobat viewer which is also a free download – http://www.adobe.com/products/acrobat/readstep2.html
From the Melling site, for those who didn't follow the link & read the tech note...
High Volume Pumps: Advantages, Myths & Fables
Most of the stock automobile engines are designed to operate from idle to 4500 RPM. The original volume and pressure oil pump will work fine in this type of application. As the demands on the engine increase so does the demands on the oiling system and pump.
The oil pump's most difficult task is to supply oil to the connecting rod bearing that is the farthest from the pump. To reach this bearing, the oil travels from three to four feet, turns numerous square corners thru small holes in the crankshaft to the rod bearing. The rod bearing doesn't help matters. It is traveling in a circle which means centrifugal force is pulling the oil out of the bearing.
A 350 Chevy has a 3.4811 stroke and a 2.111 rod journal. The outer edge of the journal travels 17.5311 every revolution. At 1000 RPM, the outer edge is traveling at 16.6 MPH and 74.7 MPH at 4500 RPM. If we take this engine to 6500 the outer edge is up to 107.9 and at 8500 it is 141.1 MPH. Now imagine driving a car around a curve at those speeds and you can feel the centrifugal force. Now imagine doing it around a circle with a 5.581, diameter.
The size of the gears or rotors determines the amount of oil a pump can move at any given RPM. Resistance to this movement creates the pressure. If a pump is not large enough to meet the demands of the engine, there will not be any pressure. Or if the demands of the engine are increased beyond the pumps capabilities there will be a loss of oil pressure. This is where high volume pumps come in; they take care of any increased demands of the engine.
Increases in the engine's oil requirements come from higher RPM, being able to rev faster, increased bearing clearances, remote oil cooler and/or filter and any combination of these. Most high volume pumps also have a increase in pressure to help get the oil out to the bearings faster.
That is what a high volume pump will do. Now let Is consider what it will not do.
It will not replace a rebuild in a worn-out engine. It may increase pressure but the engine is still worn-out.
It will not pump the oil pan dry. Both solid and hydraulic lifters have metering valves to limit flow of the oil to the top of the engine. If a pan is pumped dry, it is because the holes that drain oil back to the pan are plugged. If the high volume pump is also higher pressure, there will be a slight increase in flow to the top.
It will not wear out distributor gears. The load on the gear is directly related to the resistance to flow. Oil pressure is the measure of resistance to flow. The Ford 427 FE "side oiler" used a pump with relief valve set at 125 psi and it used a standard distributor gear. Distributor gear failures are usually caused by a worn gear on a new cam gear and/or worn bearings allowing misalignment.
It will not cause foaming of the oil. With any oil pump, the excess oil not needed by the engine is recirculated within the pump. Any additional foaming is usually created by revving the engine higher. The oil thrown from the rod bearings is going faster and causes the foaming. This is why high performance engines use a windage tray.
It will not cause spark scatter. Because of the pump pressure there is a load on the distributor gear. The number of teeth on the oil pump gears determine the number of impulses per revolution of the pump. In a SB Chevy there are seven teeth on each gear giving 14 impulses per revolution. At 6000 RPM the oil pump is turning 3000 RPM or 50 revolutions per second. To have an effect on the distributor, these impulses would have to vibrate the distributor gear through an intermediate shaft that has loose connections at both ends. Spark scatter is usually caused by weak springs in the points or dust inside the distributor cap.
High volume pumps can be a big advantage if used where needed. If installed in an engine that does not need the additional volume, they will not create a problem. The additional flow will be recirculated within the pump.
TOOLOW91
7,147
234
S.I.NY
Wrong answer...
Sorry that I am off on it sucking the pan dry , according to many builders that is the case .
As far as being clearanced and having larger mains for the HV pump To do it’s job this seems to be law by just about every person you speak to and is even mentioned in your quote . I have been to 7400 rpm with a stock melling with no issue and made over 720 Rwhp with it . With no indications of any pressure issues in my data logs .
Again personally If the engine doesn’t have large enough tolerances for that extra amount of oil it’s moving with the pressure sky high - my concern would be the oil almost becoming a brick wall at that pressure and not dispersing evenly and getting around the bearings the way it should because it can’t physically get into the space .
@srtthis what ya think ?
jrichker
Mar 10, 2000
27,401
2,846
234
74
Dublin GA
lowendmac.com
My engine builder specifically instructed me to use the standard volume Melling oil pump on my 331.
The point is that Melling builds oil pumps for Ford and GM, that is their business. I believe that they know what they are talking about since they work closely with the engineers who design the engines we are all so vocal about.
When Ford builds engines that make 430+ HP and no N02 or pressurized induction power adders from about 281cubic inches and wind up to a 7000 RPM redline and still offer a standard warranty, that says that they know what the are doing. There isn't an engine builder around that can do all those things and offer the kind of warranty that comes with one of the new Coyote engines.
Reactions: TOOLOW91
TOOLOW91
7,147
234
S.I.NY
Coyotes have a flawed geroter pump in them from the factory . Ford oem ones are prone to failure at 7000 plus mind you . The oil pump gears literallybreak apart from unbalanced harmonics inside the pump and the oil begins to cavitate. Usually wipes out the engine . QUE - Companies like TSS and Boundary to have the fix with a better gear and different pump backing plates.
marcelo
160
29
38
59
Melling sells 3 different Pumps for 302...... the M68 Standard volume.... the M68A high pressure.... and the M68 HV High volumen ..I used the M68 HV in both of my 331cu..the HV pump has a larger Body then the other Pumps = more Volumen... this Pumps made like a 60PSI Pressure at idle when cold and a little less when hot..now the High Pressure Pump makes like 80PSI at idle cold and drops to 60 when hot but when reving up also pressure goes up to 80 again...with 10/30 Oil...i also used a Stock style 5 quart Canton Oil pan with the HV Pump with one of my engines and it never sucked the Pan dry at high revs...
7991LXnSHO
Now I want a 10 year badge
Sep 1, 2010
2,605
427
124
Kearney, NE
No matter what pump you use, please use a HD pump shaft. The stock ones can end up looking like a broken Twizzler, even with a stock type pump. It happened twice on my 79, once with the stock, high mileage 302, and then on the first highway run with the E-7 5.0 crate rebuilt motor from Marshall/Blueprint motors.
Reactions: marcelo
marcelo
160
29
38
59
ARP Shaft always
Steel1
Mustang Master
Aug 18, 2017
1,014
445
113
50
Connecticut
Believe it or not I made a Twizzler out of an ARP shaft.
Had a C-clip somehow come loose from a rocker and a piece of it lodged itself in my Melling pump.
Needless to say I purchased all new Comp gold rockers.
  • Wow
Reactions: 7991LXnSHO
Thread starter Similar threads Forum Replies Date
2013 Geee T Will a little too much oil hurt anything? SN95 4.6L Mustang Tech 5
X Too much pressure - Oil getting out of catch can SN95 4.6L Mustang Tech 2
pwcracer Too much oil? 1994 - 1995 Specific Tech 6
B What do you think, too much oil vapor??? Fox 5.0 Mustang Tech 7
L could too much oil cause pcv valve to pop off? Fox 5.0 Mustang Tech 4
40th GT too much oil? :-0 SN95 4.6L Mustang Tech 15
BlackVert too much oil? 1994 - 1995 Specific Tech 11
ill advised Too much oil pressure? If so, how/why? Fox 5.0 Mustang Tech 14
beaver2489 too much oil!?!?! Fox 5.0 Mustang Tech 12
T Need good/affordable cooling fan for Mach 1 that does not vibrate too much 1996 - 2004 SN95 Mustang -General/Talk- 3
9 Too much fuel ? 1992 5.0l Fox 5.0 Mustang Tech 21
C Too much timing? Digital Self-tuning Forum 15
Flatfoot Engine Too much vacuum? Fox 5.0 Mustang Tech 8
M Too Much Fuel Stabilizer - Please Advise 2005 - 2014 S-197 Mustang -General/Talk- 3
nelzfoxes Fox Too Much To Tackle Myself? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 15
D Lifter Problems Too Much Pump Classic Mustang Specific Tech 2
1 Too Much Fun.... The Welcome Wagon 5
skiwesser11 How Much Nitrous Is Too Much? Fox 5.0 Mustang Tech 20
Repostyle Too Much Clutch Pedal Travel Fox 5.0 Mustang Tech 13
R 65 Gt Vert T10 Drive Shaft: How Much Rotational Play Is Too Much Rotational Play? 1965 - 1973 Classic Mustangs -General/Talk- 0
V Porting Track Heat Intake- 1262 Port Too Much Fox 5.0 Mustang Tech 3
J Too Much Horsepower???? Seriously 2005 - 2014 S-197 Mustang -General/Talk- 5
bdepedro Too Much Compression! Classic Mustang Specific Tech 34
P Is This Carb Too Much For My Setup? 1965 - 1973 Classic Mustangs -General/Talk- 2
Badwolf Mgw Short Throw Shifter Needs Too Much Force To Shift 2005 - 2009 Specific Tech 11
esr209 Too Much Fuel Pressure? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
from6to8 Function Of Too Much Air Or Too Little Air, Iab Valve And Idling Of 94-95 Gt's 1994 - 1995 Specific Tech 2
D Too Much Mileage For Head Swap? Fox 5.0 Mustang Tech 5
TheShabz Did I expect too much? 2005 - 2014 S-197 Mustang -General/Talk- 8
F Brakes SN95 Cobra brake swap - Too much pedal effort Classic Mustang Specific Tech 5
W too much injector? SN95 4.6L Mustang Tech 5
D Battery draw - How much it too much ? Fox 5.0 Mustang Tech 1
oz 488 Rwhp - Stock Short Block.... Too Much? Fox 5.0 Mustang Tech 18
mackblaze S-trim, Seemed Like A Good Idea. 11:1 Too Much? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
B Electrical Tfi Sinking Too Much And Overheating, What Else Can I Check? Fox 5.0 Mustang Tech 9
jozo5150 Engine How Much Air Is Too Much? 2005 - 2009 Specific Tech 3
M camshaft endplay, too much? Other Auto Tech 1
enyawix Are AFR 165 too much for gt40 intake? Fox 5.0 Mustang Tech 24
B 2004 cobra 24,000, too much? SVT Tech Forum 3
S X Pipe at WOT is too much 1994 - 1995 Specific Tech 0
Slow LX stock 5.0 with powerdyne 30lb injectors too much? Fox 5.0 Mustang Tech 3
mtmc Would a 2" drop be too much on 18s? SN95 4.6L Mustang Tech 24
Ateup Too much rain, not enough Stang time... 2005 - 2014 S-197 Mustang -General/Talk- 14
NIKwoaC Putting too much though into a fuel pump Fox 5.0 Mustang Tech 2
Desertdave351 I cut too much off, now I'm in trouble Classic Mustang Specific Tech 2
N 1 Quart too much in Aod trans Fox 5.0 Mustang Tech 9
Pingvinov How much hp is too much? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 109
M new guy here - too much carb ? Fox 5.0 Mustang Tech 10
C SN95 BOOSTER too much for stock braked GT? Fox 5.0 Mustang Tech 1
P Replacing Structural Parts - Cut off a little too much - tips for lining things up? Classic Mustang Specific Tech 7
