the 5.0 bellhousing will not work with a tremec either. if you are going with a tko, you will need a new bellhousing regardless. it would be much more cost effective to just wait for the 408.AP1995V6 said:I'm piecing together a 408 and I'm slowly adding stuff to it; however, i don't have much experience driving a manual so I was going to go ahead and mate the tko600 with the v6 before I drop the new engine in.
What are the differences between the 5.0 bellhousing and a 3.8 bellhousing?
94-302-vert said:Why learn on the trans you want to have around for a while.
i dont believe the tk-600 uses straight cut gears, might be an option though. mine shifts smooth and for the same price it holds an extra 100 ft/lbs over the tk-500miller92063 said:i went with the tko-500 because the tko-600 uses strait cut gears. it shifts harder and louder.(what i have been told)
