what would be better to use the 180 or 195. the stock one is at 195 and i heard its better to run a little bit cooler? what do you think? gt40p heads and e cam other than that stock.
if you trick the computer and make the engine run richer... won't that reduce performance??
An old racer's trick in stock class is to use the 180F or lower to fool the computer into thinking it's still cold and run a bit richer for slightly more performance.
(You can get a better constant rich condition by simply unplugging the O2 Sensor wire for short drag race runs. It takes 5 minutes from cold start for an O2 sensor to "lightoff" and affect the mixture to lean anyhow in a normal engine.)
A. You will get lower gas mileage slightly but better WOT performance.
B. This might cause you some issues during an emissions test requiring a fully hot engine? So you should change it back to 195F before your test. (Or just unplug the O2 wire.)
C. Either 180 or 195F both work well. So depends on if you live in an emissions State or not?
