I had a 4R70W with a full manual valve body built. It was rated and tested at around 800HP which is far more than I'll ever need. It can be driven as easy-going as a stocker or as hard-shifting as you want. Of course, you can get an automatic valve body or one that allows it to be electronically or manually controlled, but this is what I wanted.
Here are the specs:
4R70W w/electronic OD
Full manual valve body
Cryogenically-treated Internals
Line pressure modulation/blow-through system w/TransGo bypass
Alto Red & High Energy clutches (int 4, fwd 5, rev 4, direct 7)
10" Forged 3000RPM lockup converter w/large carbon lockup clutch
Welded carbon OD band, input shaft, high grade stub shaft
B&M heavy duty transmission cooler
