Somehow these wires got disconnected, what are these wires that go into the transmission? Does it hurt anything to leave them disconnected, what do they do? Thanks guys
Got any pics...that would help us out...i can only think of a few things that it could be because I know there is only a few "wires" that go into the transmission...
Auto or man trans? Only things go to the trans are, neutral saftey switch(auto) reverse light switch(man), speed sensor for the trans if equipped. Anything not working? Can you see where they plug in? Are you sure it's actually for the trans? Have you had anything appart recently? Hope this helps out.
its a manual trans, when i pulled the codes i got a code for the nuetral saftey switch... reverse lights work, if it doesnt hurt anything i will just leave it alone, neutral saftey switch - i dont need that, reverse light works, so im sure that everything is fine... thanks!
